Magnaflow CB sound clip?
Wow that's a great price! Thanks for including the seller info.
The long down pipe also deletes the cat? You would think this would net the most gains but could also be the louder option. It will be interesting to hear what others went with and their experience.
The shorty dp only replaces the OEM down pipe. With the shorty, you retain the OEM O2 housing. While the shorty, in theory allows for higher flow than the stock down pipe, it doesn't really change the flow characteristics like the long dp does. With the OEM O2 housing, you basically have a collector that all the exhaust gases from the turbo and the waste gate get dumped into before being shoved into the down pipe.
So, in theory, while you could see gains w/ the shorty, the long dp should yield even better gains due to the better handling of the exhaust gases...
**resource cited: http://www.ultimate-racing.com/xcart...&cat=77&page=1
One-piece design replaces both OEM cast "O2" Housing, and Downpipe
instigator
Dec 15, 2003 09:03 AM
mrdecibel
40
Dec 9, 2003 12:11 PM
