2010 Ralliart OEM ECU Test Write Error
Old Apr 8, 2011 | 09:37 AM
MonacoGP's Avatar
I'm trying to load a tune on a friend's new 2010 Ralliart. He purchased a pill from GST. Car is otherwise sock.
Before uploading a tune I tried a test write and received the following popup:
EcuFlash Error ...... an error occured see log for details.
Log is as follows:
[11:53:14.046] EcuFlash Version 1.43.3150
[11:53:14.046] OS Version Windows XP
[11:53:14.046] Qt Version 4.6.2
[11:53:14.078] 62 memory models read.
[11:53:14.078] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[11:53:14.531] 387 ROM metadata models scanned.
[11:53:14.531] checksum module "subarudbw" loaded.
[11:53:14.531] checksum module "mitsucan" loaded.
[11:53:14.531] checksum module "mitsuh8" loaded.
[11:53:14.531] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[11:53:14.531] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[11:53:14.531] flashing tool "wrx02" loaded.
[11:53:14.531] flashing tool "wrx04" loaded.
[11:53:14.531] flashing tool "sti04" loaded.
[11:53:14.531] flashing tool "sti05" loaded.
[11:53:14.531] flashing tool "mitsukernel" loaded.
[11:53:14.531] flashing tool "mitsukernelocp" loaded.
[11:53:14.531] flashing tool "mitsubootloader" loaded.
[11:53:14.531] flashing tool "shbootmode" loaded.
[11:53:14.546] flashing tool "shaudmode" loaded.
[11:53:14.546] flashing tool "subarucan" loaded.
[11:53:14.546] flashing tool "mitsucan" loaded.
[11:53:32.406] 53600009 (0 tables) inheriting 53600010 (84 tables)
[11:53:32.437] 1048576 byte image read.
[11:53:36.375] J2534 API Version: 04.04
[11:53:36.375] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[11:53:36.375] Device Firmware Version: 1.11.3137
[11:53:36.375] Device Serial Number: TABFxV6f
[11:53:40.125] -- loading kernel --
[11:53:40.125] -- connecting to kernel --
[11:53:40.125] kernel get version
[11:53:40.453] ECU HW part number : 1860B308
[11:53:40.468] ECU SW part number : 1860B30801
[11:53:40.484] -- unlocking ECU --
[11:53:40.484] starting session...
[11:53:40.484] requesting seed...
[11:53:40.484] sending key...
[11:53:40.812] -- uploading kernel --
[11:53:40.828] .
[11:53:40.843] .
[11:53:40.859] .
[11:53:40.875] .
[11:53:40.890] .
[11:53:40.890] .
[11:53:40.906] .
[11:53:40.921] .
[11:53:40.937] .
[11:53:40.937] .
[11:53:40.953] .
[11:53:40.968] .
[11:53:40.984] .
[11:53:40.984] .
[11:53:41.000] .
[11:53:41.015] .
[11:53:41.031] .
[11:53:41.031] .
[11:53:41.046] .
[11:53:41.062] .
[11:53:41.062] .
[11:53:41.062] -- connecting to kernel --
[11:53:41.062] kernel get version
[11:53:41.078] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[11:53:41.078] reading kernel comm buffer size
[11:53:41.078] comm buffer size set to 1024
[11:53:41.078] reading kernel flash buffer size
[11:53:41.078] flash buffer size set to 4096
[11:53:41.078] -- test flashing image to ECU memory --
[11:53:41.484] -- comparing ECU flash memory pages to image file --
[11:53:41.484] seg start len ecu CRC32 img CRC32 same?
[11:53:41.500] FB01 00000000 00002000 43948F8F 01121021 NO
[11:53:41.500] FB02 00002000 00001000 61D4C2BC 2F74E0AC NO
[11:53:41.515] FB03 00003000 00001000 C6E8D226 9283C6B0 NO
[11:53:41.546] FB04 00004000 00004000 A3EF3A94 7622F8F9 NO
[11:53:41.609] FB05 00008000 00008000 F1276B7D A087C65F NO
[11:53:41.718] FB06 00010000 00010000 5D53D5CA 2AE138BB NO
[11:53:41.843] FB07 00020000 00010000 8DCF000B 630F7C3D NO
[11:53:41.953] FB08 00030000 00010000 6C2B3446 FCC849AD NO
[11:53:42.078] FB09 00040000 00010000 D2D5F9BC 5D91B296 NO
[11:53:42.187] FB10 00050000 00010000 D304E450 7240340E NO
[11:53:42.312] FB11 00060000 00010000 9ECDF522 A537CEB8 NO
[11:53:42.421] FB12 00070000 00010000 1D51F6DF 674ED37F NO
[11:53:42.531] FB13 00080000 00010000 74D49DE3 0FBCE881 NO
[11:53:42.656] FB14 00090000 00010000 CBA8F5D6 CECF57E0 NO
[11:53:42.765] FB15 000A0000 00010000 B942EADE 2971B93C NO
[11:53:42.890] FB16 000B0000 00010000 DEAB7E4E F2E1DEF5 NO
[11:53:43.000] FB17 000C0000 00010000 DEAB7E4E DEAB7E4E YES
[11:53:43.125] FB18 000D0000 00010000 DEAB7E4E DEAB7E4E YES
[11:53:43.234] FB19 000E0000 00010000 DEAB7E4E DEAB7E4E YES
[11:53:43.343] FB20 000F0000 00010000 38439CF7 38439CF7 YES
[11:53:43.343] the image you are trying to flash contains changes to protected areas! exiting.
[11:53:43.343] interface close
[11:53:43.375] interface close
Any insight would be greatly appreciated.
Thank you!
Attached Thumbnails 2010 Ralliart OEM ECU Test Write Error-2010ralliarttestwriteerror.jpg
Old Apr 8, 2011 | 09:42 AM
Mad_SB's Avatar
looks like you are using the wrong map to me. You have 2009 base map open and trying to flash into a 2010 car.
You should save his stock rom first anyway, when you read the stock rom you cna confirm what version of the GST basemap you need. If the stock rom id is 55590006 or 7 then it is the 2010 basemap you need.
Old Apr 8, 2011 | 09:51 AM
MonacoGP's Avatar
I did a backup of the OEM ROM before doing anything.
Thank you for the fast response. I'll try the 2010 ROM. DUH!!! on me.
Old Apr 8, 2011 | 10:41 AM
MonacoGP's Avatar
All fixed. My friend has a big grin on his face. Thank you again for the quick reply. Sorry for my ignorance I usually only do Evo's and thought the 2010 was the same as the 2009 on the Ralliart.
Old Apr 8, 2011 | 11:02 AM
Mad_SB's Avatar
glad you got it sorted!
Old Apr 8, 2011 | 02:06 PM
RazorLab's Avatar
Except that 2010 is a 2010, not a 2009 that is a 2009.
Glad you got it figured out.
city
Jun 2, 2017 08:34 PM
CeliOnce
Sep 14, 2015 09:46 PM
qwertykerr
Dec 11, 2012 06:00 PM
jba3
Sep 25, 2009 12:14 AM
