Single Tip vs. Dual Tip
Old Aug 24, 2011 | 09:28 PM
AnthonyB's Avatar
Is there any advantages or disadvantages of either, i know single tip exhausts are way lighter, and I've see the hp gains of both and they are similar, sound of dual tips are a lot better on most vids I've seen. Is the flow better on dual tips or is there just an extra hole?
Old Aug 25, 2011 | 08:32 AM
zx-319's Avatar
It's mostly a matter of esthetics, the dual-tip usually looks much more performance. On a ralliart it has no reason to be, since the air flow requirements of the engine are being met by practically any aftermarket exhaust.
Where a dual-tip exhaust is beneficial is if you have a V8 (or V10 or V12, anything with 2 headers) engine, with very efficient heads and approriate valve/cam setup and a fully double exhaust then it's beneficial.
But any 4 cylinder (inline) should be fine with a sufficiently large single exhaust.
A single 3 inches pipe flows 12% more than two 2 inches pipe. (EDIT: it's 12% more, not 18%)
Old Aug 25, 2011 | 08:50 AM
Exyia's Avatar
a single will always flow better because of less turbulance/bends/etc
dual tips are purely for looks
V6/V8/etc can utilize dual exhausts, not dual tips, and benefit. but with a 4cyl, all the exhaust gases are going through one pipe. to split it at the end for dual-tips will disrupt flow
but performance difference depends on the car/setup. on the stock RA turbo, you're not flowing that much air anyway, you probably won't get a huge performance hit from dual if you really wanted the look
AJV
Dec 9, 2016 02:49 PM
daasca
Mar 14, 2013 10:28 AM
StormtrooperX
23
Jun 3, 2012 05:34 PM
kimma
17
May 4, 2012 01:19 PM
rtype02
11
Jul 13, 2011 05:07 PM
