SST Cooler?
Old Dec 28, 2012 | 10:33 AM
Accursed's Avatar
SST Cooler?
For a car that probably will never hit the track, is it worth upgrading the SST Cooler?
If it overheats you simply get a "Drive Slower" msg and at that point you would know if you really need the upgrade or not?
Old Dec 28, 2012 | 10:59 AM
deprydation's Avatar
I would say it's a worthwhile upgrade even if you're DD'ing it. Always a good thing to keep the SST temps in check no matter the driving conditions.
Now if you're DD'ing do you need a full blown out race cooler? Probably not, but some kind of upgrade will always help extend the life of your precious 10 thousand dollar transmission and the highly expensive fluid in it.
Old Dec 28, 2012 | 04:53 PM
richardjh's Avatar
I'd recommend installing a temp-sensor-controlled fan on it. Mine switches on at 65C (at the cooler), and in summer it is often running. Any time the ambient temp is over 35C, I can expect it to run - after a 30 minute drive, it'll start coming on each time I stop. It simply makes sure the air cooler keeps on working efficiently, even when not moving at highway speeds.
Rich
Old Dec 28, 2012 | 06:29 PM
Slee256's Avatar
Rich
Where do get such a product? Is it a bolt-on item?
Old Dec 28, 2012 | 10:06 PM
nunyas's Avatar
jegs... and pretty much.. there's some wiring you need to do to make it work, and then there's some adjustments you'll need to do to make it kick on when you want it to
Old Dec 29, 2012 | 02:55 AM
evox2277's Avatar
I've did it just for peace of mind but also because I upgraded to a evo x turbo haha but
I've installed a cxr racing 25 row trans cooler on my RA. I've even removed the fog lights just so more air would hit it! My RA is also a DD with a few sprinted driving once while!
Shifts got really smooth after doing the upgrade.
Old Dec 29, 2012 | 04:02 AM
richardjh's Avatar
Here is my setup...
https://www.evolutionm.net/forums/mi...st-cooler.html
Rich
Old Dec 29, 2012 | 09:33 AM
nunyas's Avatar
that link is giving a 404 :\
Old Dec 29, 2012 | 09:49 AM
richardjh's Avatar
Stupid mobile interface.
Will find it when I'm next on my pc.
Rich
Old Dec 29, 2012 | 06:12 PM
richardjh's Avatar
Link fixed.
Rich
Old Jan 9, 2013 | 03:34 PM
bruisednaner's Avatar
Old Jan 9, 2013 | 05:33 PM
Jasoob's Avatar
I can help you out with an SSP SST cooler if you want...PM me
Sligo
Jun 21, 2016 07:07 AM
Jasoob
May 10, 2012 07:51 AM
skyseer
Sep 28, 2011 03:17 PM
voodooman79
Mitsubishi TC-SST Discussion
240
Dec 21, 2009 10:24 AM
Madrican
Automotosports - Illinois
Sep 14, 2009 04:43 PM
