ACD C161e code
Old Jan 8, 2016 | 05:08 PM
gally's Avatar
Originally Posted by DWILSON357
Take it to the dealer, the acd pump is covered under an extended 10 yr warranty from the factory. They'll just replace the pump.
I don't think they replace it unless the pump is 100% failed which would be the c161f code not the c161e I'm showing. hopefully they still honor all warranty issues anyway due to me being modded as well.
Old Jan 9, 2016 | 06:38 AM
DWILSON357's Avatar
I had c161e...they created it said to drive it...warmed it up in the parking lot it came back....brought a mechanic outside and he checked it....1 day later I had a new pump
Old Jan 9, 2016 | 06:46 AM
DWILSON357's Avatar
I geuss it depends on how your dealer is as well
Old Jan 9, 2016 | 02:23 PM
03chi-town0Z's Avatar
You have the codes mixed up. 161E IS the failure code. Bring it in and they'll replace it. You can call ahead to confirm, but I've replaced dozens since they issued the warranty extension and 161E is what Mitsu wants to see to authorize replacement.
161F is the pump protection mode code and they won't always replace for that one.
Old Jan 12, 2016 | 01:23 AM
gally's Avatar
okay thanks a lot appointment made for next wednesday hope all goes according to this info. appreciate it guys.
Old Jan 30, 2016 | 06:15 AM
gally's Avatar
finally got it all sorted, had to wait for the part to show up but they ended up replacing it. thanks for the help guys. should I get the relocation kit for the pump?
Old Feb 1, 2016 | 03:52 PM
A lot of people do just that. Wait until the pump fails then once you have a brand new unit from Mitsu relocate it to prevent future failure.
Old Jan 18, 2018 | 07:21 AM
ultm8mind's Avatar
Veteran: Army
Is it true about the replacing the pump with the 161E? Because it just popped up on mine and I'm stationed in Germany...fml
Old Jan 18, 2018 | 09:12 AM
DWILSON357's Avatar
Yes it is 161e, I was mixed up
Old Jan 19, 2018 | 08:45 AM
ultm8mind's Avatar
Veteran: Army
Anyone have it where it states it's covered by warranty? Called over here to the dealer that's close and they don't speak English so I need some leverage, haha...
Old Jan 21, 2018 | 03:58 AM
DWILSON357's Avatar
In North America they extended the pump warranty to 10 year 100k miles(Not 100% sure on the mileage)...i believe in the other markets your screwed.
Old Jan 29, 2018 | 04:37 AM
ultm8mind's Avatar
Veteran: Army
I will try to call Mitsubishi of America and ask if I'm overseas how I can handle it...
Old Sep 4, 2018 | 05:38 AM
ultm8mind's Avatar
Veteran: Army
What is the part number for the pump, anyone know off hand?
Old Sep 5, 2018 | 04:21 AM
DWILSON357's Avatar
I do not know the Part number, but there are rebuild kits out there if you are handy. They are something like 200-300 USD
Old Jan 28, 2020 | 05:33 PM
korman's Avatar
c161e but not the pump
I'm new to the forum so I don't know if I'm in the right place for this.
I have a 2014 Ralliart and just had the acd pump replaced under warranty in September 2019, I was pulling c161f, after the replacement no codes were showing. fast forward to December 2019 my awd service light comes on, and pulling c161e. took it back to dealership and they said it was most likely the acd cpu, they couldn't find where the issue was coming from. replaced the acd ecu myself. the dealership the pump is working fine just can't find the problem. any ideas on what to do?
