CBRD RAD Lite installed - some questions
Old Jun 8, 2013 | 11:58 AM
ivan308's Avatar
I had a CBRD RAD Lite installed on my 2009 Ralliart yesterday.
I have a few questions from those that also have RAD Lites.
1) I thought the turbo was supposed to come with a 20psi waste-gate however with the the waste-gate connected directly to manifold with no boost control I only got 14 psi of boost ?
2) The RAD Lite seems to have much more turbo whine than the stock turbo ?
3) What boost levels are you running and how is the boost response . Can you provide some sample log files ?
Thanks
Old Jun 8, 2013 | 08:19 PM
Slee256's Avatar
Did you get a tune at the time of installation?
Old Jun 9, 2013 | 11:43 AM
veuve's Avatar
Tunning does sound like the problem. Isn't internal waste gate connected to the dp?
Old Jun 11, 2013 | 02:14 PM
CBRD's Avatar
Ivan-
returned your call yesterday- left you VM---
We do run an 18.5 psi actuator- not all are exactly at that psi- restrictions in downpipe and so forth can affect it- as can humidity in temps---
The louder noise is from the billet compressor wheel and different aero-
Car definetly needs a tune with the turbo swap!!
cb
CBRD
Sep 21, 2014 04:34 AM
khami
Dec 13, 2013 09:22 AM
Rylinkus
Jun 8, 2013 01:41 PM
ivan308
26
Mar 27, 2013 09:46 PM
CBRD
38
Mar 15, 2013 12:41 PM
