Ralliart turbo upgrades
Buy tomei arms turbo, ams intercooler, tomei titanium intercooler pipe, and oil line and fuel injectors. Also you would have to replace your transmission to heavy duty gears mrt performance.au has it Bret Middleton is a genius shoot him an email but he takes a long time to reply though. Your stock transmission can only handle up to 350 and still be reliable anything more and you will have to upgrade your transmission.
I am trying to find a way to upgrade my 09 ralliart to have 400-450 horsepower. I have looked in a lot of topics but i cant really find any big turbo upgrades, the main thing i am seeing is just turbo swaps to the evo turbo. Is this the best way to go then upgrade the intercooler, intake and exhaust system?
This is the exact thread I needed to read! I have a 2011 Ralliart and I am hoping to push 400HP as well with my car. This thread seems to have the right recipe to achieve what we want. I am on a budget as well but will be saving up for the transmission upgrade since that seems like it will be a must. Thanks for all the input guys, you have made it much easier for me to learn and put that knowledge toward my car. Build it right the first time!
IF we can be of assistance check out our RBX line of turbos
http://www.cbrdspeedfactory.com/cbrd...b-x-turbo-kit/
cb
cb
cb
cb
uhm no... Intercooler and pipes FIRST... then the turbo. The Ralliart intercooler is nearly insufficient for the stock RA turbo let alone something larger like a X turbo.
There are no bespoke Ralliart big turbos. They're all for the EvoX. So, you'll have to get one of those. You don't have to upgrade to an X turbo first, but you do need to make sure you have all the EvoX turbo mounting hardware to upgrade to something bigger than a X turbo.
Myself, I skipped the OEM X turbo and went straight to the BBX Lite. The parts list is exactly like the EvoX turbo swap parts list, with the turbo being the primary difference.
The transmission in the ralliarts are the same as the evo X MR so likely nothing needs to be upgraded there as long as the power level doesn't get too high. And yes, after an exhaust, intake, intercooler and turbo change, a tune would be required.
darkblues24
Mar 30, 2016 07:11 AM
Jake RA
Nov 24, 2015 02:16 PM
