stupid boost pill installation question
Old Oct 20, 2013 | 12:59 PM
chrylaser's Avatar
Hi guys, I just received an arms boost pill. I have a mapengine for it. Two newbie questions. I moved the stock clamps but I'm having a hard time getting the tubing off to remove the pill. Any suggestions or tips? also, should I use the same clamps again or use a zip ties? lastly, will using a boost pill with a proper map significantly decreased the life of my engine ? I've heard mixed things. Thanks everyone.
Old Oct 20, 2013 | 03:10 PM
GingerBear's Avatar
Just keep wiggling/tugging. It'll come loose. You'll want to get a long flexible piece of plastic to stick in there to push it out once you do get it loose, and to get the new one in place.
Use the stock clamps. I can't think of a good reason not to. Even without them I'm not sure how far it could possibly travel, but then again I can't remember exactly how snug the fit was and the size of the nipple it connects to.
It shouldn't cause any damage or unnecessary wear to your engine. This is the same engine used in the EVO. A boost pill and a tune is pretty tame in comparison to what many people have done to these engines.
Old Oct 21, 2013 | 08:10 AM
Veronica's Avatar
^ all true.
Me? I used a long reach needle nose pliers to rotate the hoses back and forth a bit to help release them.
I used a small diameter phillips screwdriver to push the old one out and the new one in.
Stock clamps are better than zip ties, so re-use them.
Old Oct 21, 2013 | 10:03 AM
chrylaser's Avatar
Thanks for the tips!
OC
Apr 15, 2013 08:33 AM
EndlessRed
33
Apr 4, 2011 09:42 PM
mfp5011
11
Jun 17, 2010 11:55 AM
mrfred
Nov 7, 2008 03:25 PM
racer135
Apr 8, 2008 02:29 PM
