fmic piping
Old Nov 19, 2013 | 12:47 PM
mjp10mlrsb's Avatar
fmic piping
i bought the UR uicp half set for my ralliart because i wasn't planning on changing to the evo x fmic. now that i've changed my mind, is that pipe still useable if i get the stock or aftermarket elbow from the fmic?
Old Nov 19, 2013 | 01:24 PM
stfuad's Avatar
afaik if the pipe is ralliart specific you need a different length coupler from the uicp to the ic assuming the uicp and ic pipe sizes are the same.
Old Nov 21, 2013 | 11:05 AM
mjp10mlrsb's Avatar
it is a 2.5 inch pipe so i guess its the same as the stock evo x. just have to get the pipe from the intercooler itself. thanks! My other concern is the lower piping. with the sst tranny i'm assuming i can only use piping from the mr and not the gsr?
Old Nov 21, 2013 | 11:44 AM
DEREK199574's Avatar
Just get a reducer coupler and you should be fine! I think it's 63mm to 60mm coupler.
And as for the LICP from what I've heard, they appear to be the same. I could be wrong though...
Old Nov 21, 2013 | 12:04 PM
mjp10mlrsb's Avatar
thank you! i thought the licp were different because of the tranny cooler on the drivers side behind the bumper cover? i could be wrong too!lol
Old Nov 24, 2013 | 03:11 PM
dangina's Avatar
From what I have read the bottom is the same, only the top pipes you gotta change, been looking at doing this upgrade. Does anyone know that if you switch to the bigger fmic, do you have to do a tune?
Old Nov 25, 2013 | 11:35 AM
mjp10mlrsb's Avatar
i believe if its the only mod on the car, you dont need a tune. if you add exhaust or intake etc. then you do need a tune.
CurseDSM
May 19, 2012 08:53 AM
Dre1189
20
Feb 19, 2010 10:28 AM
Srt4...
Apr 27, 2009 07:12 PM
darkside2
Mar 21, 2008 12:34 AM
Jeeperjunior
Feb 29, 2008 05:43 PM
