4wd system needs maintenance
I have a 2010 RA with roughly 80k on it. Recently, an alarm that says "4WD sys. needs Maint.". I was wondering if anyone else in here had that alarm before. I do regular maint. with the dealer so I take care of her real good. I just want to know if this is normal at this stage of the vehicle. Any input would be appreciated.
step one - check ACD fluid level in the right/rear hatch area (but only for the coolest of Ralliarts
) I don't know where it is on the sedan - but probably same place in the trunk.
Is it low? (you will hope so...)
Pull the fuse until you take it to the dealership...
) I don't know where it is on the sedan - but probably same place in the trunk.Is it low? (you will hope so...)
fluid for the sedan is in the right side of the trunk aswell, my acw pump died right around 80k on my 09, hopefully its not the case with yours but its a strong possibility, go to the dealer and take it from there
irvin302
Aug 10, 2016 10:27 AM
twycross
22
Jul 15, 2010 02:07 PM
