RA vs Evo X Downpipe?
Old Dec 1, 2014 | 04:11 PM
GetFoxed's Avatar
What is the difference in the OE downpipes between the RA vs EvoX? Is the piping the same ID size? Is there any difference?
Trying to determine if it is worth it to go to aftermarket Downpipe vs EvoX downpipe vs RA downpipe?
Old Dec 3, 2014 | 11:08 AM
GetFoxed's Avatar
Bueller Bueller Bueller
Anybody...Nothing?
Old Dec 4, 2014 | 12:04 AM
AlDim's Avatar
The difference between the RA and Evo X downpipes is that the former is designed to work on your car and the latter isn't lol. Evo X one can only be used if you change your turbo. Aftermarket ones aren't all that useful for basic builds - no restriction there. I'd only recommend changing this part if you're doing a full turbo back exhaust.
Old Dec 4, 2014 | 07:26 AM
GetFoxed's Avatar
Well I have to change mine, as my current flange to the Cat is old an warped and will not mate well to the new HFC I installed.
And I just found this thread...after a lot of searching.
https://www.evolutionm.net/forums/09...test-pipe.html
Still what is the difference between the EVO X shortpipe and the RA Shortpipe? Anything?
Old Dec 12, 2014 | 11:00 AM
neogeo64's Avatar
The Evo X downpipe has 2 pieces. the lower is the same as our Ralliart which bolts right to our turbo. You can buy an Ultimate racing downpipe or use oem Evo X if you take off the upper section.
KeDoSH
Nov 10, 2012 09:25 PM
opjohnsmith
Jun 5, 2010 01:09 AM
qaz003
Lancer Aftermarket Forced Induction Tech
May 19, 2010 09:32 PM
exhaust_note
Jun 3, 2005 07:06 PM
fury656
72
Apr 8, 2005 10:07 PM
