Bov
Old Jul 21, 2015 | 01:52 PM
kaj's Avatar
kaj
Originally Posted by Strangways
Even if it is creating an actual rich condition, could it be fooling the o2 sensor into reporting a lean condition instead? Or am I just trying to blame a mod that I myself wouldn't have chosen?
A car running rich can't present as being lean. That's the opposite. Plus, you would only be rich between shifts. Running lean during normal operation is different.
I'd look into other sources for your issue.
Old Jul 21, 2015 | 02:41 PM
Strangways's Avatar
Thank you, kaj! I appreciate the sanity check, because I'm just getting hung up on this darned BOV
Old Jul 21, 2015 | 04:49 PM
kaj's Avatar
kaj
i feel ya. sometimes i over think and mix myself up sometimes. then someone will hit me up with a real "duh" moment. LOL. i count on my friends and people here to keep my thought process on track.
maybe i have ADD haha
Old Jul 21, 2015 | 09:00 PM
Strangways's Avatar
Well kaj, I owe you thanks, and I owe my BOV an apology. The vacuum line for the fuel pressure regulator valve had popped off, and somehow I missed that simple little detail that made all the difference. Sorry for the threadjack, folks!
Old Jul 21, 2015 | 09:06 PM
kaj's Avatar
kaj
that would explain it. glad you found your solution!
Old Jul 28, 2015 | 01:59 PM
Mivec20's Avatar
VTA BOV can create idling / stalling issues on gear changes. However, if you stay within that 50/50 you should be fine... all my buddies run VTA.. however I'm the exception.
With our car, when there is a cut in throttle, the pressurized air needs somewhere to go. When recirculated, this air is reused and sent back to the air intake. The ECU is expecting this recirculated air. When you vent this pressurized air to the atmosphere, you're throwing it away when the ECU is expecting it, causing stability issues.
I upgraded to the EVO X BOV from eBay (About $150) and it was quite a noticeable upgrade. While changing gears WOT around 5-6k you feel so much more torque leading into the next gear which is quite enjoyable ;D
Old Jul 28, 2015 | 03:13 PM
kaj's Avatar
kaj
Precisely. The MAF metered it and fuel has been added accordingly.
How did a DV net you more torque??
Old Jul 28, 2015 | 05:34 PM
Mivec20's Avatar
Typical newbie seat of your pants driving gauge... "more torque" sounds pretty LoL as it should be.. but I mean, It just feels more edgy ;p...
dvd_mi
16
Nov 19, 2009 05:27 PM
GOKOU
Jun 23, 2004 08:39 PM
ku7484
Apr 12, 2004 05:09 AM
rraulston
10
Apr 2, 2004 07:31 AM
