greddy bov doesn't sound like a greddy bov
Old Apr 9, 2004 | 05:34 PM
ku7484's Avatar
watsup everyone. Anyways, the sound of my bov has changed a total of 3 times. My Greddy Type S bov was my first mod, and when i installed it, it pretty much sounded like the bird chirping... but not that loud bc i ddn't have a intake. Few weeks later i get the RMR intake, and it made it ALOT louder, but more of a swoosh sound. You couldn't hear it too loud in first gear when i drove normally. ANd It would sound like a bird whistling when i barely let off the gas. Well today i added the RMR intake (induction) pipe, and now it sounds straight up SWOOOSH or KSHHHHHHHh. Still has the tiny bird sound when i let off the gas. But i did get the sound back in 1st gear.
Plus ever since i added my Intake, my intake is so damn loud at high RPMS (ex. 6000-7000) that its hard to hear my bov.
OKAY so anyways.. i thought the Greddy Type-S was supposed to sound like a laser/whistle/swoosh/pig squeel. Yah know? but now its basically just air. Is it possible im leaking? i have no clue.. CAN OTHER GREDDY TYPE S OWNERS TELL ME HOW THEIRS SOUND.
Old Apr 9, 2004 | 05:42 PM
Novtec1's Avatar
Veteran: Army
sounds like a bird chirping.....and you really can't change it. unless you get another bov.
Old Apr 9, 2004 | 05:43 PM
ku7484's Avatar
you see mine doesn't sound like that at all... hmmmm..
Old Apr 9, 2004 | 05:44 PM
Novtec1's Avatar
Veteran: Army
did you do the evo "mod" and take the spring out if not go theres another thread not too far down that explains it.
Old Apr 9, 2004 | 06:07 PM
ku7484's Avatar
yahh
Old Apr 9, 2004 | 06:56 PM
MYEVO8U's Avatar
So, you are running the large spring only right? OK the high pitch chirp is increased when you tighten the adjustment screw on the top of the valve. I have found that 9 threads from the top of the nut was too soft with almost no chirp. Then down to 6 threads was very high pitch (probably where you want it, but too much for me). So I keep mine at about 8 threads out. Becaose of your MAS pipe you may have to crank it down a little more than I did.
Old Apr 12, 2004 | 05:09 AM
Brandnuevo's Avatar
I also have a similar problem wif the bird chirping thing ... so u say about 8 threads down is a good settiing ?
hmm think ill try that out ... does it make much of a "whoosh"
noice then ... thanks ?
KillaYayo
Apr 21, 2017 11:03 PM
eVo_316
Feb 25, 2011 09:28 PM
rjsdxm
19
Aug 7, 2007 02:01 PM
PKEVO8
12
Sep 6, 2006 03:09 PM
