Smoking at idle
Smoking at idle
I've noticed this problem in the last few days and was hoping someone could help me out. If my car is idling for awhile, like sitting in a parking lot not the short time at a light, the exhaust starts smoking. My rpms seem to fluctuate as well when it starts smoking. Once I start driving everything is fine and no more smoke. I've been checking the oil and I don't see anything in it and it's keeping it's level. The coolant looks fine as well but has gone down a bit. I replaced the pcv valve as I've read that could be the problem but it's still doing it after the replacement. Could it be a bad head gasket even though I'm not getting any contamination in the oil or coolant?
First - is it steam (water vapor) or smoke?
If it is white and doesn't really smell like anything and water is dripping from the exhaust tips - it is the head. The lower coolant level supports this. You would not necessarily see coolant in the oil. You can confirm with a compression test.
If it is bluish and smells kinda' like oil -it is (Dant, dant, dah!!) leaking oil past a piston ring or valve seal. Again, a compression test and leak down will guide you.
If it is black`ish - it could be fuel from going super-pig-rich (like a injector temporarily stuck open).
So... let us know a bit more.... Maybe pix if unsure.
It's very random when it happens so I'll try to get a pic or video next time if I can. It's not black and it doesn't look blueish but it's hard to tell. It does have a smell to it though. If I was burning oil I would think my oil level would be going down and it's not.
I let it sit and idle yesterday when I got home from work and after about 10-15 minutes it started smoking. It wasn't pouring smoke, just enough to notice it. Tried to take a picture but it didn't show up in the pictures. I'll check the plugs and see how they look, I just changed them a couple months ago.
Did you ever figure out what was causing this?? I have the same issue with my 2020 Kia Stinger
Toxin
15
Mar 14, 2009 12:47 PM
