2014 RA ECUflash XML file
Old Dec 25, 2017 | 05:19 AM
Kaitos's Avatar
So I just went through the effort to reflash with the GST basemap. I've got a 2014 RA and my ROM ID is actually 59570005. However, the only ROM definitions available are for 59570004. I imported the cars ROM but ECUflash wasn't able to read it. I haven't really seen people post about having that issue even with the newer RAs.
So what I did to be able to read the ROM was to edit the definition file. I changed the name of the file from 59570004 to 59570005. Then I edited the actual file. Within the first few lines of code, you can see the ROM ID twice. I changed that value as well from "59570004" to "59570005". After that, I was able to read and write to the ECU.
would doing it this way cause the logging issues I'm having?
Old Jan 1, 2018 | 06:24 PM
DWILSON357's Avatar
What logging issues are you having?
what you did does not sound like a good idea...THERE is a reason the ids were different. Sometimes you can update the rom but you really need to know what's going on to do that..tgats where folks like razorlab, golden, and tephra come in
Old Jan 1, 2018 | 06:35 PM
Kaitos's Avatar
well I'm not having any logging issues anymore (Was having some non-related logging issues before/after reflash due to not using the right ECU) The IDs are different because the year of car is different. The 04 number is for the '13 model and there are no available definition files for '14 and '15. With my ID being 05 instead, the 04 file will not let ecuflash read my ROM. Everybody on here says that the 04 file should work for the '14, which should mean that all I have to do is make ecuflash recognize my ROM by changing what it "looks for" from the '13s ROM to a '14s ROM.
Old Oct 6, 2020 | 06:23 PM
RalliBastar's Avatar
I would like to confirm that by doing a save as on .xml file 59570004 located in C/programfiles/x86/OpenECU/EcuFlash/Rommetadata/mitusbishi/evo and saving it as 59570005 2014 USDM Lancer Ralliart SST.xml in the same location will allow you to open the stock .rom from your 2014 Ralliart.
You must manipulate the .xml in notepad and change the <xmlid>59570004</xmlid> to <xmlid>59570005</xmlid> on line one within the <romid>
Also change line 3 <internalidhex>59570004</internalidhex> to <internalidhex>59570005</internalidhex>
Also change the 9th line <year>2013>/year> to <year>2014>/year>
Save the file as an .xml in C/programfiles/x86/OpenECU/EcuFlash/Rommetadata/mitusbishi/evo
close ECUFlash and reopen. You should now be able to read your stock .rom for this model and year using ECUflash
when you read from ecu memory the ROM should open without asking you to use the wizard.
Hope this helps someone.
kambodianboi
Sep 26, 2023 11:50 AM
evo8john
Sep 6, 2023 05:58 AM
duranvw
Sep 20, 2015 07:46 PM
bostonhatcher
Mar 6, 2010 06:48 PM
ohthree
Nov 7, 2007 10:01 AM
