question on dyno result
Old Aug 26, 2020 | 05:42 AM
Ralliarto's Avatar
Question question on dyno result
the only engine/powertrain related mods i have on are xForce turbo back exhaust (3in) and AEM airbox.
i have some questions about the manifold pressure chart. after the tune, the reading is around 244kpa, or 35.4psi. to calculate boost pressure, i need to subtract 1 atmospheric pressure aka 14.7psi from it. 35.4 - 14.7 = 20.7psi. is 20.7psi my actual boost pressure? or have i made a mistake in the calculations? that seems kinda high for a bone stock engine and turbo. if my calculation isn't wrong, then doesn't 186kW(250hp)/378nm(280lb`ft) on the wheels seem low for this level of boost?
Old Aug 26, 2020 | 09:13 AM
RazorLab's Avatar
Those numbers are high for those two mods and no tune. Need an evo x turbo for that
Old Aug 26, 2020 | 06:12 PM
Ralliarto's Avatar
the numbers are after the tune though. you think the dyno sheet number could be inacurate?
Old Aug 27, 2020 | 09:36 AM
RalliFast's Avatar
I'm not sure about your calculations for the manifold pressure but the HP and Torque numbers don't seem impossible(maybe a little generous) with a tune... What method are you using to up the boost pressure? i.e. boost pill or aftermarket boost controller or some other method I'm unfamiliar with?
Old Aug 27, 2020 | 09:59 AM
RazorLab's Avatar
Well, that dyno sheet is using 1.76 correction, so yes, and it's a mainline.
Curves look good though.
mr2racer7
12
Dec 27, 2009 01:23 PM
OMEGA BLACK 79
Aug 23, 2009 06:16 AM
XRS-Lift
Apr 17, 2004 07:49 PM
SlowCar
Nov 20, 2003 12:50 PM
