09 Ralliart engine help
Old Jan 9, 2023 | 09:31 AM
G5hz's Avatar
I have an 09 ralliart that wont start with a new battery. I tried to hand crank the engine by the powersteering pump belt and it turns backwards just fine but doesn't turn forward. Through the oil cap i can see the cam spin fully around as im cranking it. When trying to start the engine no belt will move altough sometimes it spins it a little bit up to the certain point where it was cranked back.
I would appreciate any help.
Old Jan 9, 2023 | 10:47 AM
RobbieOh's Avatar
5 Year Member
Did anything out of the ordinary occur right before this no-start situation?
Old Jan 9, 2023 | 01:46 PM
G5hz's Avatar
The car was bought off an auction. engine bay seems to be filled with yellow dust which I speculate is coolant that has dried up (has a sweet smell), there is oil in the engine at normal levels but it's dark. I really don't know what was happening before because it got hit in the back. could the engine be seized?
Old Jan 10, 2023 | 11:37 AM
G5hz's Avatar
I took the belt off and what do you know. It started right up. seems like something from accessories is broken allowing it to turn only backwards
Old Jan 10, 2023 | 02:01 PM
RobbieOh's Avatar
5 Year Member
The plastic idler pulleys seem to be a common failure in these motors.
josh11
Jul 2, 2019 03:49 PM
TheMort
Nov 1, 2013 10:46 AM
LancerOzClint
23
Apr 26, 2011 10:44 AM
Matt-Jagg
25
Jun 3, 2006 11:16 AM
Obsoleteasian
Lancer Engine Tech
Jul 29, 2002 02:59 AM
