HOW TO//Sirius Radio//Non Sirius lancers
Old Sep 30, 2009 | 03:48 AM
Jake26's Avatar
Here you go i just placed it here.. works fine no signal loss
Old Sep 18, 2012 | 07:53 AM
Chris0102NY's Avatar
I just bought a 2008 lancer es. And when i press the sirus button it just gives me a code to put in somewhere. What do i have to do with that code?? Help me
Old Jan 29, 2013 | 05:45 AM
Griever92's Avatar
Question
Does anyone happen to know if you can connect the factory satellite antenna with the Sirius SCC1C module?
If possible, i'd rather use what's on the car already, rather than mounting another antenna.
Old Mar 18, 2013 | 05:15 PM
pltek's Avatar
fast forward 3.5 years.
2013 base GSR, should have checked first, instead bought the sirius module and...no plug and play behind the glove box. i have a sirius module if someone wants to buy it
Old Oct 2, 2013 | 09:44 AM
mitsuPHIL's Avatar
Hi there... another question for those who have done this... (great step by step, BTW! Thanks!)
I have 2013 Sportback SE (Canadian version of the base Sportback). I have the OE radio, no R/F version, just the stocker. It has no RCA aux input, but does have USB input/voice control, Bluetooth.
I just checked, and it looks like I have an empty harness taped against the rhs behind the glovebox. If I get a sirius module and plug it in, will I simply get another option when I press the "Radio" button? There is no "Sirius" button on my headunit...
Appreciate the help, and thanks again to the OP for doing this guide.
Cheers
Phil
Old Oct 11, 2013 | 10:32 PM
mitsuPHIL's Avatar
Well, I went ahead and ordered one. I also called Sirius and they said the esn number on the one I was looking at was good to go... Fingers crossed that it works!
Old Apr 17, 2014 | 07:29 AM
high_boost_drif's Avatar
well i have Rockford fosgate fact radio 6 cd changer i plug the sirius module nothing happens #8701A216, i when the mitsubishi and they don't know they told i should bring another day to plug scanner i might some reset $55.00 for the scan so i don't what else to do
Old Jan 21, 2016 | 10:38 PM
Francis Zablan's Avatar
i have a 2009 lancer and im connected to the bluetooth so i can use for calling someone or receiving a call but it won't work when i try to play music from my phone. Please help me.
Old Jan 6, 2022 | 06:34 PM
HoodieWeather's Avatar
5 Year Member
So. since the Sirius Module doesn't come with a harness. You will need an aftermarket antenna to be plugged into the yellow port, and then the white port should be used with the harness from the Nav system I take it?
porovoz916
Nov 2, 2017 01:04 PM
Dominic Shelley
Lancer Troubleshooting
Nov 28, 2016 07:34 AM
pltek
Oct 26, 2016 07:15 AM
Maxtor
Apr 23, 2016 03:58 PM
patkelley
For Sale - Cars For Sale
Mar 20, 2016 07:39 AM
