Bulb replacement?
Old Mar 8, 2012 | 06:49 PM
DaJackson's Avatar
Bulb replacement?
I just got a set of LEDs form Performance LEDs and I'm not sure how to get at a couple of the bulbs.
For the map lights and dome light do I just pull them down from the headliner? In past cars I've just had to pull the lens off but it doesn't seem to work the same on the RA. I don't want to start pulling and break some clips.
Also how do I get the side markers off?
Old Mar 8, 2012 | 06:53 PM
sstevojr's Avatar
I'm wondering the same about the map lights, I burned out a bulb recently.
Do you have a link to where you got your bulbs from?
Old Mar 8, 2012 | 10:15 PM
DaJackson's Avatar
http://www.performanceleds.com/
A friend of mine from when I had my GTI owns this company. He has been mainly working on getting VW conversion kits made. This is the first kit he's made for the Lancer/RA/Evo. Once we're both happy with the results he will put the package up on is website.
He's an uber nerd and takes everything to the next level so the LEDs are all top notch made in the USA stuff. It took him 3 weeks to find the right LEDs that met his standards for our cars. I'm expecting to be fully impressed once I get them installed.
Old Mar 9, 2012 | 06:53 AM
TurtleRA's Avatar
Take a look in the manual, it shows you how to get the covers off. You just need a flat screwdriver and pry it off, it is pretty easy once you apply pressure on the correct points. Also, pretty sure you can't take the side markers off, or at least can't change the bulb. Think I saw some place where it says they are a sealed unit.
Old Mar 9, 2012 | 09:36 AM
DaJackson's Avatar
Ok I'll check the manual. I didn't think it would show it since they try to get you to go to the dealer for pretty much everything these days.
As for the side markers I thought I saw someone who swapped them to LEDs but that might have been custom build.
Old Mar 9, 2012 | 11:18 AM
DaJackson's Avatar
Good call on the manual, looks like all the bulbs are listed.
Old Mar 14, 2012 | 04:00 PM
xDarKnighTx's Avatar
I just replaced the map lights a couple months ago.
All you need is a small flat screw driver. Press the map light as if you are turning it on, but keep it pressed. Slide the screw driver into the opposite edge of the "button" side, then slowly pry it open while still keeping the light button pressed.
Old Apr 13, 2012 | 03:54 PM
sstevojr's Avatar
Thanks for the info on how to get the map light cover off; I'll have to swing by Pep Boys and get a new bulb this weekend
Old Apr 13, 2012 | 11:45 PM
Bunny Chow's Avatar
try pepboys or napa
Old Jun 12, 2012 | 02:47 PM
DjRags604's Avatar
I'm missing the manual. Can someone the numbers for the map lights?
tomevoix
Mar 25, 2021 06:18 PM
shadow1
Dec 4, 2013 04:40 PM
t5caveman
Apr 7, 2012 10:10 PM
Turvo
Aug 20, 2010 07:05 AM
czapski
Canadian Forum
Nov 23, 2008 03:41 PM
