Removed noserine w/o bumper
omg removing the ring was a pita....im just going to go w/ with you said and only using less screws...it was tighten in such hard spot to reach...and i made the mistake to only did like 2 coats ...shoulda done 4 coats; 30sec each... :[ well at least when it starts coming off ill do it again w/ a breeze! Thanks for this info; else i would have never done it...taking off bumper is too much work lol.
Looks god Gilbert , never noticed this but i never paid attention , no wonder i like your RA so much
lol
Might chip the paint in a couple weeks though bro , if it does happen my friend that paints will do it for dirty cheap with good paint .
lolMight chip the paint in a couple weeks though bro , if it does happen my friend that paints will do it for dirty cheap with good paint .
ive had it on for like it month lol..and it still looks the same haha.
Was going to do this today. I should have looked for instructions to remove the black cover first but after fighting it for awhile I looked and found that on an Evo thread.
Now I have a problem because I cant get the two clips off the airbox shroud. Last summer my front bumper was replaced after an accident and I have to believe the bodyman stripped these plastic screw clips. I've tried to pull off the shroud, but Im worried about damaging the other end when the clips let go. I also started to pop it with a screwdriver, but the plastic seems fragile and again I dont want to break anything. Any ideas?
It's normal to try to turn those plastic screw clips and have nothing happen....they're junk. I don't think mine ever "unscrewed" when the car was new. The way I loosen those two is by pushing upwards on them from underneath with my fingertip or a small screwdriver. Beats trying to pry them out (and scratching the clips all up).
-Taranis
I just finished my nose ring and the process was pretty easy mainly thanks to this thread. Having a stubby screwdriver is a must.
Two things I noticed that were different between the write up and my 2010 Sportback. First, the screws at the top of the lower mesh were 10mm bolt heads and not philips. Also, I didnt have any of the tape on the ring as mentioned in the write up.
Once I finish the window trim I'll put up some pics in the Newbie section.
