09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
plasti-dip
Old Sep 3, 2010 | 06:52 PM
  #121
gccruz's Avatar
You don't have to take apart the housing for that. It's a 194 LED replacement. Look in your manual for replacement instructions.
Old Sep 4, 2010 | 06:56 AM
  #122
SnipeRA's Avatar
OK thanks. But in the picture it looks like that god awful yellow reflector was removed from his headlight. Is it even worht the trouble to remove that. i would want to get water inside the headlight after messing with it.
Old Sep 4, 2010 | 07:22 AM
  #123
08Lancer89's Avatar
I baked the light in the oven took it apart and blacked it all out I have a thread. Titled. "blacked out headlights non SSS" look at that.
Old Sep 4, 2010 | 04:07 PM
  #124
SnipeRA's Avatar
I want to do this so bad i took a look at your other thread if this car wasn't my DD and the only car i owned i would be able to send you the lights to get it it done (if your still doing that). any chance i could get a PM of a "how to?"
Old Sep 8, 2010 | 05:32 AM
  #125
FasterNU08's Avatar
Originally Posted by Sweetness1892
hey how did you black out the body piece that runs across the middle of the two grills in the front? Im going to use plastidip for the chrome that is in the front but i want to know how to do the body piece. Did you just use plastidip or what?
I believe he is talking about the front lip portion that is blacked out below the nose ring. I was also wondering if you guys use plastidip or is it some sort of adhesive film???
Old Sep 8, 2010 | 06:53 AM
  #126
mikesim's Avatar
most guys used a custom cut film.
Old Sep 8, 2010 | 08:14 AM
  #127
luckyjakob's Avatar
Most of the people i've talked to used Plastidip for it. Just take off your lower grill, mask off the bumper and do it
Old Sep 8, 2010 | 09:13 AM
  #128
08Lancer89's Avatar
I did mine in plastidip.
Old Sep 8, 2010 | 01:25 PM
  #129
FasterNU08's Avatar
I believe I have seen both and both look great. But I was also wondering how the plastidip vs. the film ages? Does the plastidip chip easier? Where would one aquire such a film to custom fit. Does the mitsu dealer stock them? Thanks
Old Sep 8, 2010 | 03:29 PM
  #130
gccruz's Avatar
The Plasti-dip lasts a good long while. Its a rubber material, It's like wrapping it with a balloon, so it will be less likely to chip. That is if you put down about 4-6 coats and prep the surface.
Old Sep 9, 2010 | 07:42 AM
  #131
luckyjakob's Avatar
I blacked out my grill will Plasti-dip at 2 coats and it's holding up fine. No chips at all
Old Sep 14, 2010 | 09:04 PM
  #132
Gman4ver's Avatar
looks good, white and black car great combo
Old Sep 28, 2010 | 05:15 PM
  #133
Big Steve's Avatar
I did my nose ring the other day. I also did the Mitsubishi emblem. I think it turned out pretty good!
Old Sep 28, 2010 | 06:09 PM
  #134
08Lancer89's Avatar
That's what mine looks like. Where did you get that ralliart fmic stencil.
Old Sep 28, 2010 | 07:11 PM
  #135
Big Steve's Avatar
I got it from http://shop.ebay.com/?_from=R40&_trk...All-Categories. I also found out that there is a shop by my house that also makes vinyl stencils. I had them make me 3 extra ones because I'm sure that I will have to respray it in the future.
