Engine Bay Pictures:
LiL EVO Spring Engine Bay Upgrade
I had the value cover black renkle powered coated and replaced the oil fill cap with a HKS. I also had my Intake manifold powdered coated and port & polished, I used SSP intake gaskets while installing it.AMS fuel rail in red went very well with the black manifold and Black braided fuel line looked clean. In an attemp to clean up I did a minor wire tuck and will do a major wire tuck in the fall. Any brackets that were easy to remove I also sent to get powered coated, ECU, Fuses, Return Fuel line. My vaccumn lines that went to the intake manifold and oil catch can got renewed to help. A black mishimoto Raditor hose kit also was installed. More powered coating will happen in the fall. Also a custom strut bar front and rear made from aluminum will constructed in the fall.
PM me-
[/IMG]
