09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
EVO X MR BBS wheels on RA'10
Old Jan 10, 2011 | 11:35 PM
chazyronnie's Avatar
hey guys just wanna share how the BBS wheels fits the RA (UPDATED)
Wheel Size: 18x8.5 +38 offset, Center Bore 67.1
Tire Size: 245/40R18 Yokohama Advan A13C (MY2008)
Comments: Forged, wheels are 18.5 lbs; wheel + tire ~43 lbs.
the good:
*BBS is so much lighter than the OEM wheels
*steering feels light as well
*excellent handling
*looks so much better the the stock wheels
*NO RUBBING issues with swift spring
the bad:
*increase ride height because of the fatter tires even with swift springs
*front wheels stick out
*slightly affects gas mileage because of the wider tires
Uploaded with ImageShack.us
front wheels
Old Jan 10, 2011 | 11:55 PM
Jdunn502's Avatar
Beautiful
Old Jan 11, 2011 | 01:07 AM
dmun505's Avatar
the good:
*BBS is so much lighter the OEM wheels
*excellent handling
the bad:
*increase ride height because of the fatter tires 245/60
*affects gas mileage because of the wider tires
I'm gonna have to disagree with you on those
-The ride height stayed the same for me
-The front wheels don't really stick out for me but then again, I am on RRM springs
-Gas mileage actually stayed the same and improved a little as well. I would say this is because the wheels are lighter.
BEAUTIFUL nonetheless!
Old Jan 11, 2011 | 01:49 AM
MR. EVO MR's Avatar
Looks good bro. You know these wheels bumped your whp a little.
Old Jan 11, 2011 | 02:48 AM
bye2u's Avatar
the ride height should be the same if not little less.. the tires on the BBS are 245/40 not 60 profile.. which is only 0.1" smaller than stock 215/45 so nothing in it really.. other than that looks good minus the cf band aid you have on
Old Jan 11, 2011 | 03:54 AM
robertg's Avatar
Originally Posted by bye2u
the ride height should be the same if not little less.. The tires on the bbs are 245/40 not 60 profile.. Which is only 0.1" smaller than stock 215/45 so nothing in it really.. Other than that looks good minus the cf band aid you have on :d
+1
Old Jan 11, 2011 | 05:08 AM
mTEV's Avatar
You should powder-coat them
Old Jan 11, 2011 | 06:52 AM
Jdunn502's Avatar
Where can i get me some!!!
Old Jan 11, 2011 | 08:25 AM
vplukas101's Avatar
parked evo x mr
Old Jan 11, 2011 | 08:57 AM
+1^^ dont forget your tools and jack stands
Old Jan 11, 2011 | 09:00 AM
You can check out evo guys private seller here in the forums they sell their stock wheels really cheap... The parking lot is BS
Old Jan 11, 2011 | 10:15 AM
jan_ralliart's Avatar
Looks good~
Old Jan 11, 2011 | 10:27 AM
yahh's Avatar
Looks great, I am a strong supporter of buying another vehicles stock wheels to keep , or until you can afford quality ones instead of buying cheap brands.
Old Jan 11, 2011 | 11:09 AM
Westbound&down's Avatar
i wanna know about the fenders. Are those the actual vents off an X ? If so did you cut to make them fit?
Wheels look good though.
Old Jan 11, 2011 | 11:53 AM
Geereg's Avatar
I thought we would rub being lowered on those wheels with 245s and fenders that aren't rolled?
