Why not RL Heavy Shock Proof in the TC?
Old Apr 21, 2004 | 11:00 AM
  #31
SILVER SURFER's Avatar
Well, I am actually wrestling with the question of whether to use the heavy SP or Light weight SP myself. If the light weight will give the added/needed additional gear protection even under severre road race conditions, then it would be a better choice. Mainly because it should provide better lubrication to the tight tolerance components, like the bearings, etc.
The US RL website does not have as much info as the AU site, they actually have an application recomendation section.
http://www.redlineoil.com.au/
They only have the earlier version EVO listed GSR 92-96, but they recomend the light weight shock proof even for race conditions. Now I am not sure if that takes into account guys like us who are making around 50% more power than stock?
If I was a drag racer making 400-500+ WHP this would be a much easier decision, Heavy weight without a doubt.
If you notice, for racing they also show the light weight shock proof for the transaxle. Now is that for a stock tranny or some sort of dog box?
The question is what will go first? On a slightly modified car used for street/road racing, it seems that you will suffer from damaged gear teeth long before excessive bearing wear, (if you use standard oils). But the light weight SP may have enough gear nashing protection, flow better, and use less HP, I am just not sure.
RL claims that the heavy weight should flow just like a 75-90, shouldn't that be good enough? I may have to go to one of those oil forums and see if I can get some more advice. Those guys are realy into lubricants! If they can't help, I may just have to flip a coin.
Check this site out, more than you ever really wanted to know about oil
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old Apr 21, 2004 | 11:12 AM
  #32
Zeus's Avatar
I went out and got the lightweight for me here in Austin. I don't have the power some of you guys have, and I rarely, if ever, launch/drag race the car (a side from the track, Texas street racing laws are a some*****... read go to jail, go to jail, or go to jail... car impounded).
Old Jun 15, 2004 | 09:58 PM
  #33
MyCre8n=Evlshn's Avatar
Registered User
Transfer case: 0.58 Quarts Redline Light Shockproof
Transaxle ("transmission"): 2.9 Quarts Penzoil Synchromesh (same as GM)
Rear Differential: 0.58 Quarts Redline 75w90 (straight)
Getting a $4.00 plastic lube pump at Auto Zone per recommendations rather than try to funnel and tube it.
That's what I'm going to do. Lots of reading, probably going to blow up the car.
Old Jun 15, 2004 | 10:03 PM
  #34
AMS's Avatar
AMS
I've been using RL HD shockproof in the transfer case and have been running a mix of lightweight and some superlightweight shockproof in the tranny. It shifts very nice and quick at 8800rpm and it will have the added protection if you're making some serious torque. Otherwise EVO's seem to do well on MT90 in the trans.
-Martin
Old Jun 16, 2004 | 05:34 AM
  #35
MrBonus's Avatar
-Martin
Have you had any transfer case or transmission troubles in your beast?
Old Jun 16, 2004 | 08:37 AM
  #36
AMS's Avatar
AMS
Nope, all good so far. I probably just jinxed myself !!
Old Jun 16, 2004 | 09:28 AM
  #37
Zeus's Avatar
I've been running the RL LW Shockproof in the Transfer case for a while also... no problems. Then again, I don't do the "drag thing" either
Penn. Syncroshift => tranny
RL LW Shockproof => transfer case
RL 75w90 => rear diff.
Old Jun 16, 2004 | 10:59 AM
  #38
GOKOU's Avatar
I'm going this route also but not sure whether to use LW or HW for TC. I haven't been to the track. Was planning to head there this weekend to see what times the car would hit. Any opinions? LW or HW.
Old Jun 16, 2004 | 09:11 PM
  #39
Zeus's Avatar
Are you going to a track, or a strip? If your tracking the car LW is fine... I use it for daily driving. If you are going to the drag strip (regularly), I would use HW do to all the horror stories I've heard about the transfer case letting go. I think some others are using HW on daily drivers... I just don't feel I need it for my car. Not to mention, I'm trying to increase my MPG and not decrease it with heavy fluids.
Old Jun 17, 2004 | 05:47 AM
  #40
GOKOU's Avatar
I end up buying the LW. Talk to the guy at the transmision shop and he said that LW should be fine. With HW I will loose gas mileage. Thks.
Old Jun 17, 2004 | 04:36 PM
  #41
Appauldd's Avatar
After reading several posts on the various articles about our fluids I decided to step outside the box and try something different. So far, much to my pleasure, I have a fluid that works fantastic. The greatest thing is that you can use the same fluid in all of the boxs. The fluid is from AMSOIL. the car shifts like butter and I actually saw some increase in mileage (may be placebo). It is of 75w90 consistancy, is ful synthetic, and does not require any friction modifiers. I did however put some friction modifier in the rear diff just for safe keeping.
Old Jun 17, 2004 | 05:46 PM
  #42
Jadiem's Avatar
i'm using stock fluids right now.. i'll be switching to redline when i can..
RL MT90=> tranny
how much of each should i buy?
3 quarts for the tranny and 1 for the diff and TC?
laksman91
71
Dec 20, 2014 06:51 PM
EmeryatSTM
May 31, 2009 04:50 PM
Solo II Evo
Apr 22, 2009 03:08 PM
Denverwhitetrac
Feb 27, 2007 09:10 AM
k270kmh
Nov 5, 2006 01:18 PM
