Android tablet in evo
Old Apr 20, 2012 | 11:02 PM
  #76
r34p3rex's Avatar
Originally Posted by bonlamicq
I´m looking for AC control relocation kit and double din kit, an extra help will be a good tablet to be used but not expensive (I need to repair my car; it was impacted -big- at the front).
Thanks for your help
I highly suggest picking up a used Samsung Galaxy Tab (7 inch).. they go for $100-150 now and are still plenty powerful
You can get a double-din faceplate from japanparts.com
For HVAC relocation.. just get a radio relocation plate and use a dremel to cut the hvac controls down to size Or you can have this guy hand make you one for $155: http://www.prtc.net/~cjramos54/
Old Apr 21, 2012 | 04:14 PM
  #77
bonlamicq's Avatar
Thanks i would try to do it, hope can get one a good price, and also the hand made HVAC relocation, if all goes perfect i will show you later how it finished with few pics.
Thanks...
Old Apr 21, 2012 | 05:35 PM
  #78
PatricksEvilEvo's Avatar
What about Evoscan on Android?
Old Feb 23, 2013 | 11:24 PM
  #79
shadovarian's Avatar
Evoscan on Android makes this build a lot more interesting. The tablet they offer is purpose built for evo utility. I am currently working on a full integration
The evo Droid already has the power wiring worked out. So that is one major obsticle that is already taken care of.
For my audio system I wanted to retain the bulk of the functionality that the stereo had. So I bought an Alpine X303 with Blutooth. I will load all my music up to a 32gb micro sd car on the tablet and broadcast the audio via BT to the stereo. Which was moved over to the glove box. The only thing that needs to be done to accomplish this is purchase a antenna extender and then lengthen all wires on the scosche (or whatever brand) pigtail you get to connect to your stock harness. I took a glove box to home depot and had them cut a piece of 1/8th inch wood to fit it. I am using standard buckles to mount it to the glove box cutting a square and using a gm double din and a half install kit to cover up the part of the stereo that extends beyond the wood slightly.
I didn't want to chop shop my glove box so I picked one up from a salvage yard from a base lancer for $5.
One more bit of functionality that I am adding is the app Wyse Pocket Cloud pro. It is $15, but there may be better cheaper ones. It allows you to control a windows or Mac based PC from your cell phone OR Android tablet. I will be using it to control my netbook which is plugged in to ECU+. It also has a solid state drive so no concerns about bumps destroying it.
Having the laptop connected gives me more expandability for music and tuning software not yet android friendly without having to sit it in the front seat.
I will post pictures as it starts coming together. I have already started working on the HVAC relocation, also already have the wires lengthened for the stereo and the piece of wood it is mounting to cut and ready for carpet/paint/ or vinyl depending on what I decide to go with.
Old Feb 25, 2013 | 01:09 PM
  #80
manss's Avatar
wow!
Old Feb 25, 2013 | 04:22 PM
  #81
Bklynkrs's Avatar
+1 for nexus 7.
Old Feb 26, 2013 | 12:21 PM
  #82
lonestarevo83's Avatar
Good stuff
Old May 16, 2013 | 10:20 PM
  #83
daign's Avatar
Originally Posted by rcheung
Unlike cellphones, most android tablets do not rely on internet connectivity in order for the gps to activate. Its kind of silly that my iphone needs internet for the gps to work even though one has nothing to do with the other.
absolutely incorrect. Google maps will not work without data unless you have precached for offline use your entire trip area.
You need an aftermarket nav software like Sygic in order to just use the GPS without internet/
Old May 17, 2013 | 01:15 PM
  #84
l2r99gst's Avatar
That's why Google maps has a nice offline maps option now. You just pick the area that you want and download all of the maps. That way you don't need any data connection at all if you're worried about data plans, etc.
I finally ripped out my old CarPC and putting in the Nexus 7. I need one remaining cable for my Bluetooth receiver for the amp and I will be putting everything in. I'll try to post some pics or a video when done.
Old May 24, 2013 | 05:35 PM
  #85
l2r99gst's Avatar
OK, as promised, here are a couple quick videos. I just popped this in right now, so these are the initial videos...I have to setup a bunch of stuff, but wanted to show how it's installed, and how the startup and shutdown work.
(The videos are pretty hard to see with the bright sunlight, but you get the idea)
Startup
Shutdown
Pertinent info:
Nexus 7
CyanogenMod 10 with Timur USB ROM
RTL2832 USB stick and SDR touch for radio (no data connection needed)
Bluetooth receiver connected to stock amp under driver's seat, providing audio through stock speakers
Torque with BT OBD adapter (waiting for Hamish to release EvoScan Android)
Google apps (navigation, etc)
Old May 24, 2013 | 06:28 PM
  #86
llDemonll's Avatar
K so the part I'm confused about:
is the bluetooth that's connected to the stock amp all you have? or is there a "headunit" hidden in there somewhere?
Old May 24, 2013 | 06:43 PM
  #87
l2r99gst's Avatar
That's all. No headunit needed.
The bt receiver isn't even needed...I just used it to have wireless audio.
Old May 24, 2013 | 11:26 PM
  #88
llDemonll's Avatar
Oh right, because all the amp really needs are the channel inputs..durr
That's interesting, I wouldn't have thought to do it that way!
Old Jun 3, 2013 | 02:59 PM
  #89
llDemonll's Avatar
Do you have the model of the BT receiver you're using?
Old Jun 3, 2013 | 05:14 PM
  #90
l2r99gst's Avatar
Here you go.
Keep in mind that if you want to use something like this with the stock Mitsu amp, then you need a Mitah or Mitsamp cable.
