Android tablet in evo
Old Jun 3, 2013 | 05:51 PM
  #91
llDemonll's Avatar
Hmm. So if I have a 4-channel amp that I'm hoping to wire the front speakers to and the 8" subwoofer I have, and then run the rears off of the headunit (well, not anymore I suppose; i could always just run left/right and not have fade front/rear) do you have a recommendation? or is this even possible?
Old Jun 4, 2013 | 06:21 AM
  #92
l2r99gst's Avatar
Yeah, you would just lose fade. The stock amp is 4 channel too, but tablet out is stereo and the BT receiver is stereo, so you just lose the fade.
Old Jun 4, 2013 | 07:56 AM
  #93
llDemonll's Avatar
wouldn't i need a receiver that also has a sub out line to go to the amp if i wanted to bridge two channels (the two rear channels on the sub) to run a small subwoofer?
Old Jun 4, 2013 | 08:23 AM
  #94
l2r99gst's Avatar
Hard to say what you would need, not knowing exactly your setup, etc. All I'm doing is using the stock Mitsu SSL amp and putting a BT receiver in front of it to basically add BT to the amp. That way anything can output audio (ie the tablet) to the stock amp/speakers.
If you have aftermarket audio equipment, you might not even want to go the BT solution. Maybe use a USB DAC instead and have better quality, etc. All depends on what your audio equipment has for inputs and how you have it setup, etc.
Old Jun 18, 2013 | 12:13 PM
  #95
whotippedmycow's Avatar
Looks really good. Would be nice for torque app
Old Jul 25, 2013 | 01:04 AM
  #96
LancerReplay's Avatar
I was reading this thread and saw some posts about a Ipad, I have a custom Ipad Mini dash for my GTS. I had mine built at Soundman Car Audio, I have 2 videos on the build. Thought I would post it incase you all wanted to check it out.
Soundman Car Audio (Ep. 90)
Extra Clip:
Photo:
Old Jul 25, 2013 | 04:32 AM
  #97
Tdhodp's Avatar
Pretty sure there's some vids on YouTube for tablet installs
Old Feb 27, 2014 | 02:36 PM
  #98
Bladey's Avatar
bump doing mine a few weeks just wondeirng how you guys are controlling volume on your tablets without a headunit as the volume control's will be blocked if hard mounted?
Old Feb 28, 2014 | 05:25 AM
  #99
bonlamicq's Avatar
there are some apps controling volume / screen and others, i need to look also cause i just buy one to do the same, if you find ggod apps to be used in car please let me know
Old Feb 28, 2014 | 06:08 AM
  #100
SkylineFanatic's Avatar
You really need a preamp to properly clean and amp the single from the iPad or Android device the preamp will have a control nob. For example I am using a JL Audio preamp made just for this purpose (tablets) and my volume nob is right next to cup holder in an easily accessible and discrete location.
Here are example products:
http://www.crutchfield.com/S-g4ygm1wZxVb/p_136CLRLC/JL-Audio-CL-RLC.html
http://www.crutchfield.com/S-QaivSGZkuMD/p_136441DSP/JL-Audio-CL441dsp-CleanSweep.html
Old Feb 28, 2014 | 11:55 AM
  #101
Tdhodp's Avatar
If your using an iPad the up swipe menu has volume control
Old Mar 3, 2014 | 10:03 AM
  #102
Syringe's Avatar
Check out my post I made over here where I installed an iPad mini in my car.
https://www.evolutionm.net/forums/ev...iece-ipad.html
You could follow very similar procedures for an android tablet - if you have any questions feel free to PM me, I usually check the forums every couple days.
Old Apr 25, 2014 | 03:33 PM
  #103
Nice job I like it.
gotblkr
Jun 14, 2017 08:02 PM
Kirabi
Oct 6, 2016 08:22 PM
TrogdorWBL
65
May 3, 2016 02:38 PM
JohnnyTSi
Mar 17, 2016 04:53 PM
Win
Jul 11, 2011 08:34 PM
