MBC Install Help Needed
Old Dec 17, 2004 | 11:39 AM
  #31
Jakeg97's Avatar
Originally Posted by silverEVO8
I don't know exactly what you've done, but there are a couple of ways to install an MBC but to my knowledge only one is correct. I installed an AMS MBC and the instructions were for ****. After doing it wrong and cursing a lot I finally figured it out. Here is a sketch of the installation. If you do the connections as shown, you'll be fine. Do not throw away of remove any pills from the lines. Do not throw away anything but be sure to keep anything left over so you can put it back to stock later.....
now thats a good picture
Old Dec 17, 2004 | 11:41 AM
  #32
Jakeg97's Avatar
Originally Posted by DizzyTT
I was told how to install by Al (Dynoflash) and he told me to do it to the turbo outlet and wastegate.
that is another way , but i read that the preferred (better) way is the one mattfl did , and in the picture above
Old Dec 17, 2004 | 11:45 AM
  #33
Jakeg97's Avatar
Here are the pros and cons of both hook-ups
1. Hooking it up the compressor outlet nipple:
A. This way gives you less spikes but slower spool up.
B. It does not seem to give repeatable boost. It seems
to fluctuate more with the temperature.
C. Boost seems to be harder to control below 15 psi or
above 22 psi. Almost everyone who wrote me
said this.
D. It is easier to hook up this way. No cutting any
boost lines. Plus the lines are kept shorter.
(Thus the less spikes).
2. Hooking it to the hose between the BOV and the intake:
A. This way seems to give slightly faster spool up than
the other way.
B. It gives more repeatable boost. It doesn't seem to
fluctuate as much with temperature differences.
C. The boost seems to be more controllable down to
stock turbo levels. (Like down to 7 or 8 psi for a 1G
with a stock 14B turbo).
D. It is more work to hook up. You have to cut the hose
between the BOV and intake and tee it in. (Not
that this is hard, its just an extra step so I put it
in here)
Old Dec 17, 2004 | 01:34 PM
  #34
lancealot72's Avatar
Nice, I was looking for this info as well!! Thanks guys..
Old Dec 17, 2004 | 01:39 PM
  #35
Dookie's Avatar
This may be a stupid question, but I never thought about this....can you tap into the BOV line and go straight to the wastegate without a MBC installed? Reason why I was wondering is that would vacuum damage the wastegate?
Old Dec 17, 2004 | 07:58 PM
  #36
05-EVO-GSR's Avatar
silverEVO8,
Thanks for the diagram!
Question: Would there be any problem just disconnecting the lines to the intake pipe, turbo, and wastegate, then capping off the intake pipe and turbo and leaving the hoses there in their location connected to the solonoid? It would make reversal much easier for dealership visits.
Thanks!
Old Dec 17, 2004 | 10:07 PM
  #37
silverEVO8's Avatar
Originally Posted by 05-EVO-GSR
silverEVO8,
Thanks for the diagram! !
Thanks for the good words. I knew that I would have loved to get that little drawing before I started with my MBC installation
Thanks!
I don't see any problem doing that. Actually I would strongly suggest leaving the stuff in as near the original place as possible. I would only make sure that the hoses and everything were protected and secured.
Old Dec 19, 2004 | 07:06 PM
  #38
herbal77's Avatar
My MBC was professionally done, and they didnt tap into the BOV line and now it wont hold boost, and its all the way closed and it still goes up to 21 psi, doesnt it have to be a little open in order to get t o 20psi
Old Dec 19, 2004 | 07:48 PM
  #39
herbal77's Avatar
I have a question mine was installed the easier way, what else do I have to do to connect it in between the BOV.
Old Dec 19, 2004 | 09:30 PM
  #40
Jakeg97's Avatar
make sure you use the stock hose because of the restrictor / pill in it.
https://www.evolutionm.net/forums/sh...tor+compressor
Old Dec 20, 2004 | 04:19 PM
  #41
herbal77's Avatar
I have figured it out , the pros that installed my MBC, were still connecting the selenoid to the equation. So im guessing thats why it tapers, because the ECU is still telling to taper at high rpms.
So I have to disconnect the selenoid two, and plug the 2 holes, but what do I plug them with?
and 'T' the BOV line, and thats when my boost will hold to redline.
Taking selenoid out is the way, but is it safer, will more constant boost mess something up?
thanks for all of your replys, even the bad ones..but hey we are here to learn right
Thanks EvoM.
Old Dec 20, 2004 | 04:37 PM
  #42
o4whtevors's Avatar
i had a quick question on this topic, is it posible for the dealer to tell there was a mbc in the car after you remove it. the computer wouldnt store a code or any thing would it?
Old Dec 20, 2004 | 04:58 PM
  #43
herbal77's Avatar
with what do I cap off the intake hole and the turbo hole,
Old Dec 20, 2004 | 09:54 PM
  #44
Jakeg97's Avatar
no , i have never heard of that. just be sure to reuse your stock hoses so the car will work properly
Old Dec 20, 2004 | 09:58 PM
  #45
Jakeg97's Avatar
with the provided caps included in the kit - www.boostcontroller.com
