MBC Install Help Needed
Old Dec 21, 2004 | 07:47 PM
  #46
herbal77's Avatar
I bought vacuum caps to cap off the intake and compressor, do I have to tie them down? I dont want them to pop out with the pressure
Old Dec 21, 2004 | 07:58 PM
  #47
evo542's Avatar
you should use some zip ties just to be safe^
Old Dec 24, 2004 | 08:39 AM
  #48
propellerhead's Avatar
Zip ties will work fine as long as you are using the correct size hose barbs on whatever fitting you're plugging your line to. If the hose barb is undersize, a wire tie won't keep it in place. Personally I use Oetiker clamps. They're cheaper than the damage that can be caused by a "runaway" wastegate.
Old Dec 24, 2004 | 09:01 AM
  #49
herbal77's Avatar
can you submit a picture or where to get the Oetiker clamps
Old Dec 24, 2004 | 09:36 AM
  #50
You can get Oetiker (aka ear clamps) at McMaster. Click here.
Really, there's nothing wrong with using wire ties as long as your using the same size barbs and hose. In other words, if you're using 3/16" hose, make sure you're using 3/16" hose barbs. If your hose barbs are undersize, the hose can pull off even when zip tied. Ear clamps are OEM type clamps and are much more secure & compact. They're really not much more expensive than zip ties.
Old Feb 5, 2006 | 10:56 AM
  #51
diablors's Avatar
Can you use the Tee from the stock line to tap the BOV line? If not what size Tee should I get???
Old Feb 5, 2006 | 12:43 PM
  #52
talontid's Avatar
You do not need to cap the boost solenoid... Just make sure to leave it plugged in.. There is no need to cap it because it is not hooked up anymore, there is nothng running to it..Leave those nipples uncovered, and just cap teh nipples for the turbo outlet..
Old Feb 5, 2006 | 01:18 PM
  #53
conphuzed's Avatar
For quick changes back to stock, is it smarter to hook it up the to compressor outlet nipple, so there isn't any cuts in the lines for the dealership to see?
Old Jun 15, 2006 | 06:52 PM
  #54
kaonashi's Avatar
well i hooked up like this https://www.evolutionm.net/forums/at...chmentid=21291 and im still only hitting 10-11psi, i put caps on the stock solenoid, intake, turbo, then connected wastegate to the side part of the mbc and then T inbetween the bov and intake manifold which is connected to the straight part of the mbc, anyone have any clues i connected all the zip ties and everything i checked before i installed all this stuff and i was boosting about 18ish not it doesnt get past 10 at all???
Old Jun 15, 2006 | 07:08 PM
  #55
kaonashi's Avatar
Anyone have a clue why im still only hitting this? before this i had it hooked up to the stock hose's that went to the solenoid no cutting and it was at 15psi but would not increase if i turned the knob.
Old Jun 15, 2006 | 07:36 PM
  #56
silverEVO8's Avatar
I made that sketch years ago and it's been proven many times. I don't know what could be wrong with your setup to only get 15 psi. It might be that the MBC is either defective or improperly adjusted. Can you try another MBC in its place? Maybe that will do it. The only other thing I can think of is that somehow you've missed some minor error in your installation. I know that I've made stupid mistakes many times before and checked them over and over and still not caught them Please double check everything again, or better yet, have someone else do it. A different pair of eyes can sometimes see something we miss......
Good luck
Old Oct 11, 2006 | 08:56 PM
  #57
AWDTurbo4's Avatar
Originally Posted by silverEVO8
ok I know this is oldddddddd but Im working on this as we speak
just one Q?
between the BOV and intake line....does it matter where you put the "T"....closer to the BOV..intake...middle?
thanks!
Old Oct 11, 2006 | 11:41 PM
  #58
evolrobert's Avatar
yup
Old Oct 11, 2006 | 11:48 PM
  #59
AWDTurbo4's Avatar
yup what?
yes it matters or yes anywhere?
Old Oct 12, 2006 | 12:16 AM
  #60
blackevoguy's Avatar
i used ams's mbc and i was very easy to hook up thanks to their directions
it eliminates all the stock hoses off the car and you use the kit they supply to hook it all up
you cap off the nipple under the intake and the one comin off the turbo, one line gets tapped into the bov and the other to the wastegate
simply and very effective, holds boost nicely
