Best bolt on gt30 kit ATP vs Vishnu vs Buschur
Originally Posted by 954DRGSR
It won't flow that much better - at least it didn't on my stock 03 turbo w/10.5 backhousing.
Remember I'm talking about a 30R (3037) on 109 at 36 psi. But again, the most I could probably get out of it would be 15 whp, if that. On pump gas it shouldn't make that big of a difference, so yeah, you are right.
If we are talking a bigger turbo, maybe the tubular would gain more.
Originally Posted by davidbuschur
Stock internals and 600 whp, could happen but it is going to be at high risk. As for as transmission etc. no problem. The stock clutch is not going to hold up to 600 whp.
David Buschur
www.buschurracing.com
David Buschur
well what is the best clutch to get for this power, and what internals should be changed to play it safe with 600awhp?
Originally Posted by altrix99
I beg to differ on the spool part. This is a VW 1.8T w/ said GT3076 and GT35R. Spool diff is there...
Top is 35R on C16, 3.6bar
Next down is GT30R on C16, 3.2bar (wouldn't hold that boost above 6500)
GT30R on 100 unleaded, 2.8Bar
GT30R on 93, 1.8bar
GT30R on 93, 1.8bar
On an Evo, spool and how quickly you make power on the street with a GT35r is not very far behind a 3076 and the 35r has much more progressive spoolup.
l8r)
Originally Posted by Ludikraut
Why are you posting VW dyno graphs in an Evolution thread?
l8r)
l8r)
Derek, the GT35 numbers are on straight race gas, no alky.
supernaut, the GT3076 doesn't spool that much faster than the GT35R that is why I say if you are torn between the two you may as well go with the GT35R. The 3071 will probably be fine with the 680 injectors we sell. I'll know this afternoon.
luxurybroker, spool on the new GT35R kit is 20 psi by 5,000 rpm. Lazy for a street turbo in my opinion. I haven't dyno'd a GT35r on straight pump gas.
jj008, to me a 700 rpm difference in full boost isn't worth the difference between being able to make 500 hp and 600+ hp. I'll take the 700 rpm's and the extra 100+ hp anyday.
statix, all turbo kits are held on by bolts or studs. The new kit uses studs and steel lock nuts.
David Buschur
David Buschur
hydro420evo,
For 600 hp the triple disc is going to be what you need. Our Stage 3 shortblocks whether you choose the stroker or 2 liter will work perfectly.
David Buschur
David Buschur
Hmmm, How does the 3071R Turbo flow compaired to a GT3076R? Any map comparisons?
Are you saying a GT3076R spools 700RPMs faster? That's ALOT. What about the 3071R?
Post results
But you are certian that the 3076R will make more pump gas power then as 3071R?
Post results
Sorry I cam late to this thread. If anyone has any questions about our Stg 2 kit, fire away. We've tuned enough of all the currently available turbo kits to provide reasonably accurate answers
Cheers,
Shiv
Cheers,
Shiv
how does your kit compare to the atp kit. i am really interested in the stp kit because of the power u can get out of it for the money u pay.
Cheers,
Shiv
Cheers,
Shiv
hydro420evo,
David Buschur
David Buschur
sounds great!
thnx again for the info
- Josh
l8r)
I run the Vishnu and just got rid of the ATP.
Both ran Garrett 3037's.
DynoJet Standard no smoothing:
460 whp/422 tq 109 octane
424 whp/367 tq 98 octane
373 whp/321 tq 91 octane
All pulls were made with SMART fuel turned off in 100 degree weather, so there's more hp left in there. Also, run on c-16, it might see a few more whp as c 16 adds...
