Full-race's new toys
Old Jul 24, 2007 | 02:17 PM
  #181
Geoff Raicer's Avatar
Originally Posted by Ted B
It's difficult for the masses to grasp some of this discussion, simply because it isn't evident to many here that spool characteristics and transient response are not a simple, two-dimensional affair, such as what is displayed on a dyno chart. It isn't easy to imagine what's happening. It simply must be driven to be fully understood, and that isn't a readily available option for most. This being the case, it will be a leap of faith for many at this point in time.
I have nothing to promote, nothing to sell. What I can say from first-hand experience with my own car (PT67R), and from first-hand experience with Drifto's car (GT3076R) is with the twin-scroll setups, the big turbo reacts much faster to changes in throttle position, and that makes for a much more responsive, lively feel to the car. I can definitely relate to the track experience and 2 sec lap improvement as quoted above, and I don't doubt it for a minute.
^^^ i couldnt have said it better myself. Thanks for your unbiased, honest input
Old Jul 24, 2007 | 04:38 PM
  #182
Originally Posted by Turbo Kyle
The 30R prototype looks like more of my style...plus Ill be running meth (aquiamist's fill tilt system.) Any estimates of spool on this?
here is a good comparison of a stock SR20DET with a 3071R twinscroll (Solid line) vs singlescroll 3076R (dotted line). This is a 100% stock engine, with HKS 264s and GReddy intake manifold. Pretty good indication of spool time/behavior for a 2.0L 4G63 with small cams
here is another 3071R graph on another mostly stock SR20DET where they compared it to a 2871R single scroll. whats interesting to note here is that the 2871 spools LATER than the 3071. This is counterintuitive in that they share the same exact compressor side, so the smaller GT28 turbine should spool faster due to its size. In fact, the bigger twinscroll 30R turbine is outspooling it due to the increased turbine efficiency that the twinscroll affords
Originally Posted by popadel
The one thing which bothers me (having tuned seriously for a while now STI's and Evo's) is why your 3076R spool is so late. On a 2L stock singe housing of .82 i get a 3076 to spool to 2bar by 4600
its a honda, they take a little bit to spool up check out the nissan plots above, should be a little more inline with what you are used to? Also there are a number of Full-Race singlescroll 3076R dynos on this site if you wish to compare
I have read the great thread from cover to cover, and realise there is lots of expectations of you re this TS set up being the Holy Grail of resolving Lag... My experience with TS vs single is that TS tends to be more responsive and drivable as you press on the gas (either on part throttle or as you slam on WOT). The spool time is marginaly better, especialy on a large turbo bolted to a 2L. On a 2,3 - 2,4 its a lot better with full boost coming up to 300RPM earlier, in real world comparisons. on a 2L if you get 150RPM earlier spool its a lot! Top end power always suffers more with T/S because its now got more restriction to deal with
we did a test with a honda using a gt42R where we went from divided to undivided manifold, same turbine housing. The result was over 1200rpm quicker spool, and correspondingly ~200whp/wtq gains. The bigger the turbo the faster the spool change.
additionally, if you are losing top end, you have flow problems. While it is true that a twinscroll housing will have more exhaust gas friction, the pulse conversion spool benefits at low rpm combined with the anti reversion/scavenging benefits inherent to the twinscroll have a significant upside. If you lost top end something else was wrong with the setup
Originally Posted by Zeus
Funny, but back in the day, there were many discussions on the merits of transient response on www.theoldone.com. Most thought the guy was crazy. However, he really IS a genius of sorts. It's a good read, and there are great articles on what Geoff is trying to get across to some of our thicker headed members on the merits of transient response!
Larry was always way ahead of the curve. When i was in engineering school i would spent hours upon hours on his site reading through everything he wrote. He's one of the few pioneers in this industry. While many people have had not so great things to say about his business practices, ive got nothing but praise for him and the information he's generously shared
Old Jul 24, 2007 | 06:06 PM
  #183
Turbo Kyle's Avatar
Geoff,
Thanks for taking the time to show the graphs....that 30R really rips under the curve! What was the hot side A/R on the 30r?
Old Jul 24, 2007 | 07:05 PM
  #184
no prob happy to share the info. the solid line is a .78 A/R twinscroll hsg, the dotted line is a .63 A/R singlescroll hsg
Old Jul 24, 2007 | 07:14 PM
  #185
Turbo Kyle's Avatar
Nice....I take it no one makes a twin TS 30R setup for the Evo yet? Im kinda off witht the turbo numbers....3071 is the 30R and the 3076 is the 35R right?
Old Jul 24, 2007 | 07:26 PM
  #186
actually they are both 30Rs. A GT3071R is the small 30R, and the GT3076R is the big 30R. The second two numbers in the title indicate the outer diameter of the compressor wheel in mm, the 3071 is a 71mm OD and the 3076 is a 76mm OD
the 3071R has a closer turbine to compressor match indicating better response, slightly better spool, and slightly reduced backpressure. This is the turbo preferred by our time attack test driver and our drift pilots. This turbo can do just shy of 500whp
the 3076R has a larger compressor. It can make more power than the 3071R but has slightly later spool, and slightly slower response. Most of our customers (and most evo guys) actually use this turbo and are still VERY happy with the response and spool, and they can be a bit more competitive on a drag strip. It can make a bit over 530-540whp
Old Jul 24, 2007 | 09:53 PM
  #187
Ron's Avatar
Ron
When will we see Evo-specific results of the twinscroll? The info so far is nice, and I don't want to be a wet blanket... but so far it's only speculation that these FR twinscroll setups will superior to other Evo offerings. Again, not to be a naysayer, I'm just pointing out the situation.
Didn't you do any testing before releasing them??
Edit: and by testing, I am referring to testing on an Evo...
Old Jul 25, 2007 | 04:31 AM
  #188
0100's Avatar
Veteran: Army
Can't wait to see evo specific results. Then a GB.
Old Jul 25, 2007 | 09:46 AM
  #189
Turbo Kyle's Avatar
Nice...thanks for the info again....are the turbine wheels the same size on the 3071 and 3076?
Old Jul 25, 2007 | 10:28 AM
  #190
trinydex's Avatar
depends, haha just kidding they are. what changes is the turbine housing from manufacturer to manufacturer. i'm sure there are different 30 serious wheels too but i'm pretty sure they're all generally the same.
Old Jul 25, 2007 | 05:01 PM
  #191
Originally Posted by Ron
When will we see Evo-specific results of the twinscroll? The info so far is nice, and I don't want to be a wet blanket... but so far it's only speculation that these FR twinscroll setups will superior to other Evo offerings. Again, not to be a naysayer, I'm just pointing out the situation. Didn't you do any testing before releasing them?? Edit: and by testing, I am referring to testing on an Evo...
we're working on it!! As soon as results are ready, we will be sure to post them up. The 30R evo8 is getting wrapped up this week, waiting for everything to come back from HPC. The 40R evo9 will be dynoed in 3-4 weeks.
yes, both 60mm 30R turbines, not the 56.5mm turbine that people seem to be buying
there are two 30R turbines: the small 56.5mm (for use in internally wasteagated T25 flanged 3071s) and the bigger 60mm (found on the external gate 3071, 3076, and 3082). Those are the 2 GT30R turbine wheels
Old Jul 25, 2007 | 06:26 PM
  #192
trinydex's Avatar
do people actually use the internally gated one? i've never seen that as a description on the kits available...
Old Jul 25, 2007 | 06:52 PM
  #193
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Lots of the VW guys run them and Buschur's early kits used them.
Old Jul 25, 2007 | 10:14 PM
  #194
that turbo was really designed to be used on nissan SR20DET engines where they use the stock style bottom mount manifold and a standard t25 o2 housing/downpipe. Doesnt really make much sense to use it on an evo...
Old Jul 25, 2007 | 11:08 PM
  #195
trinydex's Avatar
aha
