Full-race's new toys
Old Jul 30, 2007 | 07:48 AM
  #241
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by arpad
How about 4088 with e85?
I'm not good with calculating it out, but what I did calculate put it too close for comfort to the edge of the 1000cc... is that correct?
Originally Posted by Ted B
1200cc should suffice for that combination.
On a stock fuel system, plus a 255 Walbro and 1000 cc injectors, I am at 100% IDC with a 35R on 26 psi of boost. I'll add a FPR and another in line pump and see what happens.
Old Jul 30, 2007 | 07:50 AM
  #242
Ted B's Avatar
With which fuel?
Old Jul 30, 2007 | 04:18 PM
  #243
Geoff Raicer's Avatar
Originally Posted by Turbo Kyle
Thanks for the insight. Im interested how the 1.06 A/R will do with the 30r TS setups......its hard to make a decision on the turbo setups
unfortunately the 1.06 A/R 30R is almost impossible to get, so those results really wont matter much. The .78 A/R is actually a really good size for the 30R on a 4G63. It will be interesting to see the results of the GT35R and T3 .78 A/R twinscroll. Of course the T4 F1-35R is a great option.
Originally Posted by smartbomb
I have been trying to get the drift guys into twin scrolls and bigger A/R's for awhile. I think the Enjiku guys might finaly be trying it. Geoff, you might want to give the T350 wheels a try. A 76 trim in a divided TO4 housing flows more than a P trim, has 4 points more turbine effiecency and has 40 percent less inertia. A T350 is commonly known as the Turbonetics stage V, pre F-1.
itll be interesting if the enjiku guys end up going twinscroll... the drifters who've switched over to our twinscroll stuff have been very happy with the response and powerband, pretty much exactly what they were looking for.
The T350 is definately a good wheel. Its the first 10 blade turbine i know of? Definately ahead of its time. The only reason we arent experimenting with it is becuase turbonetics has the F1 turbine wheels, no sense in going backwards in technology. i prefer the stage V to the p trim, unless a 67 comp wheel is being used (and even then it still works suprisingly well despite the mismatch). glad to have you in this discussion mike, youre one of the most knowledgeable guys ive ever met
Originally Posted by evilbada
I have a couple questions for you geoff. I am currently running an AMS front mount with their licp and uicp. If I was to keep my current front mount and get your TS 40r without the intercooler, would I be able to modify the licp to fit the turbo? Also, what size injectors would you recommend for 40r setup? I am planning to use stock ecu/TS 40r/stock block for the moment. In the future, it will be standalone/TS 40r/built 2.3L with meth/alky no race gas. That being said, I don't want to have to switch injectors once I put them in. I guess I am looking for something stock ecu will be able to handle and still support enough flow when I use meth later on with ~30 pounds of boost.
there would be no problem using an AMS front mount on our twinscroll kit, it would just have slightly more charge piping and a horizontal core. It might even work with your LICP with no changes? not totally sure without seeing detailed pics
For the 40R, its definately going to be interesting to what the MAF can do, and if it can keep up? The injector size I normally recommend is 1000cc or 1200cc. I do not know if the stock ecu can control this big of an injector? If you had a standalone i would recommend 1000cc if its more of a street car and 1200cc if its more of a high boost car.
Originally Posted by SavEVOIX
wow...i love full-race...I used to have a mixed fullrace turbo setup on my EM1
thanks alot we've sold a LOT of EM1 turbo setups!
Originally Posted by Bikk
Hello, Full-Race Geoff, I'm in love with your work I gonna have 2.2 Cossie stroker with full build Cossie Head & other supporting mods on my Evo8, planning to do everyday drive, circuit races & perhaps some drag racing. What would be the best twinscroll setup for me 3076 or F1-35R or bigger? If I use turbo bigger than 35R do I strictly have to use custom engine management?
thanks for your compliments. The stock ecu has proven itself to work incredibly well, but i dont know how well it could control a 40R+ size turbo.. it will be interesting to find out
If you are looking to daily drive and circuit race, i recommend the 3076. If you will be doing less circuit and more drag, the 35R would be the next choice. the 40R is likely to be more turbo than you need
E85 is an awesome fuel. The turbo spools faster, you get more lowend/midrange/topend power and its CHEAP. Of course you burn through it twice as fast, but its hard to argue with. That being said 1000cc is much too small. I would strongly recommend using 1600cc if you have a 40R and E85, and you might still need even more fuel if you started to turn the boost up.
sounds like you either have the low pressure 255 pump or something else is going on? Have you watched your fuel pressure on the dyno? Its pretty likely you are dropping fuel pressure
Originally Posted by Frenchy4g63
I dont have any first hand experience with any of Full Race's products, but the pictures and testimonials should be enough to show their quality. Anyway, I can tell you Geoff is probly the nicest and most knowledgable person I've ever dealt with. I had contacted him maybe 7-8 months ago about a turbo kit. He had mentioned the twin scroll 40r then, and basically said everything that's been mentioned in this thread. He was always very quick to respond to e-mails, and very helpful. I feel bad having not gone through with the project after he was so helpful with everything. I sold the Evo, but if Full Race has any plans to start developing parts for the 335i, I wouldn't hesitate to buy anything from him. A little off topic I know, but I wanted to share my experience with Geoff, and recommend Full Race to anyone who's considering a top notch turbo kit. I'm glad to see Full Race get serious about the Evo market, and wish them luck with everything. Now get to work on some BMW 335i stuff!
Thanks alot for your compliments. We do this stuff because we love it. Anything we can do to help support our customers or potential customers, we will do.
335i stuff is coming soon, we've been in touch with turbonetics as they have a test car we might be getting our hands on...
Old Jul 30, 2007 | 06:37 PM
  #244
With which fuel?
E85. I've been running it for almost a year now.
Old Jul 30, 2007 | 09:18 PM
  #245
Ted B's Avatar
Your fuel pump almost certainly isn't keeping up with the demands of the E85, as you shouldn't be at the end of those injectors. When the fuel pump falls short, rail pressure drops, and an unusually large IDC is required to make things work. A large turbo and E85 is definitely dual pump territory.
Old Jul 31, 2007 | 08:06 AM
  #246
jbrown's Avatar
robertinustin, it sounds like you've got a Walbro GSS317 instead of a GSS342 ...
either that or something is wrong with your fuel system
maybe it's time for a Buschur HO pump?
Old Jul 31, 2007 | 08:35 AM
  #247
Ted B's Avatar
There's nothing wrong with the pump. The problem stems from the fact that any E85 application demands more fuel volume than gasoline. This makes the pump reach its limits quicker than with gasoline.
Old Jul 31, 2007 | 08:44 AM
  #248
EvolutionBoy67's Avatar
Geoff,
When can we expect some dyno numbers for the GT40R TS kit.
Old Jul 31, 2007 | 08:31 PM
  #249
agreed. the best solution is to run (2) bosch pumps, but its a pain. You can do (2) walbros or even a walbro intank to a walbro inline. You will definately need to move a lot more fuel tho
^^thats it right there
as soon as its on the car and running. We are working to have it ready for the 3rd week of august. We will not disappoint... never have, never will.
Old Aug 1, 2007 | 12:04 AM
  #250
chuntington101's Avatar
bloody hell! cant wait to see that!
Chris.
Old Aug 2, 2007 | 04:06 AM
  #251
ill-luzion's Avatar
i'll prob sell my setup to get this one. i can't wait to get it!
Old Aug 2, 2007 | 09:07 AM
  #252
Turbo Kyle's Avatar
What are you running?
Old Aug 2, 2007 | 09:38 AM
  #253
MuslimEvoFreak's Avatar
Anyone think Full-Race could dig deeper into the 8s with their twinscroll setups? I think they have a chance when the 42r is released. I can't wait to see the dyno sheets on this setup.
Old Aug 2, 2007 | 09:43 AM
  #254
Ludikraut's Avatar
IDT twin-scroll will make an impact on the drag-racing scene. The benefits of twin-scroll do not translate into better top-end power, which is really what you want for drag racing.
l8r)
Old Aug 2, 2007 | 09:46 AM
  #255
l8r)
So it is basically for greater throttle response correct?
