Door Weights
Old Sep 20, 2007 | 06:53 PM
version 2 beta's Avatar
Old Sep 20, 2007 | 09:32 PM
EVOlutionary's Avatar
Back to the original topic . . . What are the weights of early EVO VIII doors vs. EVO 9 doors???
Old Sep 21, 2007 | 09:45 AM
broeli's Avatar
Originally Posted by sblvro
the evo IX have aluminum impact reinforcements(side-impact) beams which means -7.7lbs less weight than the VIII.
Here's your answer. That's the same thing I remember reading a while back.
Also, JDM doors aren't all aluminum.
Old Sep 21, 2007 | 09:58 AM
peter*g's Avatar
To continue to hijack this thread... ;-)
Does anyone know the absolute weight of the stock door? Am I going to have to just suck it up and pull one of my doors off to figure this out?
Old Sep 21, 2007 | 10:03 AM
kingkyle's Avatar
I have round numbers... I weighed my stock doors with no interior plastic and they weighed 52lbs for the fronts so... a full stock front door is about 55-56lbs
the rear door weighed 46lbs so prob 48lbs full.
Kyle
Old Sep 21, 2007 | 10:08 AM
peter*g's Avatar
So, just to be clear, rear doors are 48lbs with glass, window mechanisms, and everything? Or are you quoting weight without window materials?
How much do your new Seibon carbon doors weigh?
Old Sep 21, 2007 | 10:14 AM
kingkyle's Avatar
Fronts are about 13lbs
rears are about 11 without lexan... with... about 14
Dont mind my car... its very dirty and being worked on for the redline event next week.
Old Sep 21, 2007 | 04:43 PM
finally some competition...
Old Sep 21, 2007 | 06:09 PM
Thanks, just wanted to verify.
I was told the opposite, that the IX doors were heavier because they had more reinforcement. At least now I know I don't have to swap doors. . .
EVOlutionary
Old Sep 22, 2007 | 06:21 AM
kingkyle's Avatar
Competition?
Old Sep 22, 2007 | 11:41 AM
Balrok's Avatar
Hey Kyle, is that cage the autopower one?
Old Sep 22, 2007 | 11:44 AM
peter*g's Avatar
Is that a bolt-in cage? Not to preach at you, but if you're running the car as hard and as fast as I assume you are, you really should reconsider the cage.
I have seen bolt-in cages rip clean out of the mounting points and do almost nothing to protect the car's occupants. I can post some pictures of a bolt-in cage in one of our old BMWs that pushed so far over from a side impact that if there was a passenger they would have broken both legs.
I wouldn't race with anything but a properly designed and fabricated weld-in cage.
Just my $0.02.
Old Sep 22, 2007 | 03:57 PM
Originally Posted by kingkyle
Competition?
Isn't this the car that runs in NASA North East?
You guys will be running in the ^ that evo in Redline at Summit... Good luck!! I'll come introduce myself when you guys get there. I'll be there on friday testing and tuning.
Old Sep 22, 2007 | 05:21 PM
oneguy's Avatar
Hey Kyle where did you get the lexan windows from?
Old Sep 22, 2007 | 06:02 PM
haitec's Avatar
that`s a beauty of a trackwhore , but i would also go for a weldIN cage!
