Injector scaling and latecy for different injectors.
Old Jan 5, 2008 | 07:03 PM
  #286
wesside's Avatar
Originally Posted by razorlab
Yup, although if you ever see that Voltage you have other issues.
lol I just set it the injector voltage to those settings is that why it just idled like **** So what should I set it as? I had the scaling at 670 and just changed it to 636 along with the other ones you posted
Old Jan 5, 2008 | 07:07 PM
  #287
RazorLab's Avatar
double check what I posted if it idles like crap as that is the scaling I use for 90% of the Denso 720 equipped evos that come through the shop.
Here is a better way to read it:
Old Jan 5, 2008 | 07:18 PM
  #288
wesside's Avatar
Yea here's mine, it just seems to not idle too great and dips down. I slapped in the injectors last night and just been doing some logging today. I used the ams injector latency master and only changed timing alittle to get rid of a few knock counts. But this idle is killing me
Thank you for all of your help
Old Jan 5, 2008 | 07:50 PM
  #289
RazorLab's Avatar
If your idle is crap from just changing to Denso 720cc and using those settings then something else is amiss. Have you logged your fuel trims?
Old Jan 5, 2008 | 08:02 PM
  #290
wesside's Avatar
I'm going to go log the fuel trims I'll use mitsulogger
edit: I might add though the car feeels great Car is Pulling way hard
This is where I'm at right now from my ams tune I have no touched anything
Old Jan 6, 2008 | 03:33 PM
  #291
wesside's Avatar
so after logging fuel trims they are as follows
Fuel Trim Low 100%
Fuel Trim Mid 130.469%
Fuel Trim High 98.438%
and these stay solid at those numbers
Old Jan 8, 2008 | 08:16 PM
  #292
fastrob691's Avatar
I have the latest version of ecuflash and under my injector size scaling it shows no size, instead of 513(stock) it shows a [.], thats its and cant seem to make any adjustments. I am set to developer mode, any suggestions, just got new injectors(780cc) and am about to begin with latency and scalings.
Old Jan 8, 2008 | 10:27 PM
  #293
RazorLab's Avatar
Either switch to a ...15 rom or search on this forum for the proper defs to add to your ...13 rom.
Old Jan 9, 2008 | 07:29 AM
  #294
fastrob691's Avatar
I guess ill try that later, figured it was fill in the blank like 90% of the other eculflash features. Thanks.
Old Jan 9, 2008 | 02:30 PM
  #295
MR_EVO21's Avatar
Ive got some PTE 680's. I've scaled it at 597 and used the AEM latency table numbers. It runs fine once warmed up, cruise afr in the 13.5-14.7, but when the motor is cold, it is really lean upon initial throttle. It runs in the area of 18-19 afr when i give it gas when the engine is cold. I was wondering if anyone else has seen this problem and what you guys did to solve that. I've tried to increase the accleration enrichment to max (1.99) and it doesn't do anything..
Old Jan 9, 2008 | 04:33 PM
  #296
fastrob691's Avatar
I did a search came up empty on a link to add defs? Any suggestions, I had the 15 Rom but car was slower at the track, weird, but tested it back to back?
Old Jan 9, 2008 | 05:00 PM
  #297
RazorLab's Avatar
Sounds like too lean when in open loop. I would tweak your scaling. Do you have to abnormally richen up the WOT part of your fuel map?
Old Jan 9, 2008 | 05:20 PM
  #298
nothere's Avatar
razorlab, could he be in open loop when he starts out cold?
so he would richen up the bottom of his map?
Old Jan 9, 2008 | 05:26 PM
  #299
RazorLab's Avatar
Yes it is in open loop on cold start. He shouldn't have to touch his fuel map if he gets the scaling correct.
Old Jan 9, 2008 | 05:55 PM
  #300
wesside's Avatar
btw I think I've got it all sorted out I just had to play with scaling ended up at 622 and just had to keep playing over and over etc.. it is pretty much a pain in the *** I didn't touch my fuel maps at all
