TephraMOD V5.10
Old Dec 26, 2008 | 05:03 AM
  #706
tephra's Avatar
what do u mean no found?
Old Dec 26, 2008 | 05:26 AM
  #707
DaNy's Avatar
Copy immobilizer, init code and paste in 88590015-v5.10 program ecu, all ok
In gauge panel check engine light on and blinking, start engine up rpm at 2.000rpm and down rpm at 0, does not start the car
Old Dec 26, 2008 | 06:23 AM
  #708
tephra's Avatar
do you have autovalet enabled?
Old Dec 26, 2008 | 06:31 AM
  #709
DaNy's Avatar
Old Dec 26, 2008 | 06:39 AM
  #710
tephra's Avatar
make "enable auto-valet on fresh ignition" = 0
Old Dec 26, 2008 | 06:49 AM
  #711
DaNy's Avatar
Old Dec 26, 2008 | 08:22 AM
  #712
Mellon Racing's Avatar
Tephra I think it would be a good idea to disable the features by default...you don't want people to accidentally swap to an untuned alt map etc...
Old Dec 26, 2008 | 11:31 AM
  #713
DaNy's Avatar
Thanks Tephra all ok
Old Dec 28, 2008 | 02:29 PM
  #714
atlhesi's Avatar
tephra, what rom v 5.10 i can use on EVO 8 EDM? 2004 (99270000)
Old Dec 28, 2008 | 05:50 PM
  #715
tephra's Avatar
hrmm
maybe 96530006.
or 90550001
try it and see, make sure you disable autovalet, you might have to disable your immob but try it without first
Old Dec 29, 2008 | 07:29 AM
  #716
wreckleford's Avatar
I am having a fuel cut issue with 9055001. I should say that I am using it in a way that is not typical, it is running an Evo I with an 8 ECU. I was previously using 9360005 with no issues. I copied all of my settings over (including boost limiter/timer) to the 9055001 and now it fuel cuts. Some times as low as at 4500 rpm. The only Tephra option enabled are no lift shift, map averaging and knock cel. Has anybody else experienced this?
Old Dec 29, 2008 | 02:57 PM
  #717
tephra's Avatar
Chris - yeah im thinking so as well
altmap is disabled by default, but autovalet is the one causing most ppls problems :P hehe
wreckleford - can you disable NTLS and retest? i have a feeling its a dodgey clutch switch
Old Dec 29, 2008 | 04:49 PM
  #718
tephra's Avatar
96260009 UPDATE
Hi guys there was a minor bug in 96260009 that stopped the CEL from flashing (for knock OR valet).
I will upload a new version (with 'fix2' in the filename). However if you dont want to start from scratch just add this to you xml and then change 0x89A2 to 0x88A2
Code:
<table name="KNOCKCEL FIX" category="Mods" address="3f1ae" type="1D" scaling="Hex16"/>
Old Dec 29, 2008 | 05:32 PM
  #719
Okay, I wil try. I haven't actually tested the NLTS so you may be right.
Old Dec 30, 2008 | 02:18 AM
  #720
grayw's Avatar
Fix works fine for CEL on knock and valet mode, thanks for sorting it
96260009 UPDATE
Code:
