TephraMOD V5.10
Old Jan 4, 2009 | 03:06 PM
  #751
tephra's Avatar
more complicated, and fairly undiscovered unfortunatley..
Old Jan 4, 2009 | 10:30 PM
  #752
eitan's Avatar
I've tested 96420011.
NLTS, 1-byte seem to work. I haven't messed with valet mode or alternate maps, so I can't speak to those.
Old Jan 5, 2009 | 11:46 AM
  #753
raasfaas's Avatar
Does V5.1 include the lean spool tables or do I need to do that mod along with it? Also, is the 1byte load mod dependent on the 2byte load mod...meaning do I need to have 2byte load working in order to use the 1byte load mod.
Old Jan 5, 2009 | 02:24 PM
  #754
tephra's Avatar
1byte is seperate, just do the 1byte load, u can forget 2byte load.
lean spool is the default in the rom, unchanged by me... so u need to copy your lean spool settings across too
Old Jan 7, 2009 | 09:29 AM
  #755
Jim in Tucson's Avatar
Well, I finally got around to upgrading from the Tephra 5.1 to the 5.10. And in the process I also upgraded from the 94070014 to the 94170015 ROM.
I ran the x15 v5.10 for a week and got at least one Random Misfire CEL each day. I've now rolled back to the x14 v5.1 with no CELs. I keep thinking maybe I missed an item in copying my tune to the new ROM. I've been over it with a fine tooth comb and can find nothing.
Appreciate any ideas.
Old Jan 7, 2009 | 10:55 AM
  #756
eclipzed's Avatar
I also experienced random misfires now that I went from 008 to 015. Any ideas would definately help both of us.
Old Jan 7, 2009 | 02:59 PM
  #757
Ok, well, maybe its not just me then. I was beginning to think I was losing it.
Old Jan 7, 2009 | 03:56 PM
  #758
tephra's Avatar
jim - send me your 14 and 15 roms
i will compare them and let u know what uve missed
Old Jan 7, 2009 | 08:19 PM
  #759
That would be grand.
Send ROMs to you via?
Thanks much!
Old Jan 8, 2009 | 08:53 AM
  #760
03whitegsr's Avatar
You could just disable the P0300 check with the periphery bits.
Old Jan 8, 2009 | 08:54 AM
  #761
03whitegsr's Avatar
double post
Old Jan 8, 2009 | 09:10 AM
  #762
derekste's Avatar
you could, but it is always nice to get to the root cause of problems.
Old Jan 8, 2009 | 02:12 PM
  #763
tephra's Avatar
Jim - myforumname@gmail.com
Old Jan 9, 2009 | 12:34 AM
  #764
grayw's Avatar
Tephra, Changing MUT 41 to 0x840B on 96260009 is still not making 1 byte load log in Evoscan, any idea?
for some reason your MUT41 isn't setup properly..
just change it to 0x840B
then 1byte should work ...
dont need to worry bout 2 byte then
Old Jan 9, 2009 | 03:08 AM
  #765
tephra's Avatar
HRMM
knowing me its probably another fracking bug in that rom (bane of my existance that romid :P)
can you just check its MUT41, requestid=41 in evoscan and dbl check the factor = 1.2 for both rom and evoscan?
do you get any log?
