Disabling EGR and fuel pressure solenoids
Old May 5, 2009 | 04:21 PM
  #76
SEEnoEVO's Avatar
Originally Posted by Wicked E
You do realize that that whole sheet only applies to the USDM Evo 9?
-E
No I do not.
So do changing these in my map do nothing? Are they different?
Old May 5, 2009 | 04:22 PM
  #77
Wicked E's Avatar
Originally Posted by SEEnoEVO
No I do not.
Read the top of the sheet in fine print...
Old May 5, 2009 | 04:24 PM
  #78
SEEnoEVO's Avatar
Ok...i see that now. So what does that mean to me? The bits for the Evo8 are different I assume? And noone knows how to fix this then?
Old May 5, 2009 | 06:53 PM
  #79
Creamo3's Avatar
So are we supposed to set FAA bit to 1? I think the confusing part is that in order to Disable the EGR/Enabled Ign Advance you need to enable the bit. I'm guessing that is my issue, but I won't be able to test it out for a couple weeks until the car is back together.
Old May 5, 2009 | 06:56 PM
  #80
SEEnoEVO's Avatar
I will flash my car with this today and report back tomorrow. You mean FAA bit 11 correct?
Old May 6, 2009 | 04:05 AM
  #81
SEEnoEVO's Avatar
Ok...I changed FAA bit 11 to 1 and also changed FCA bit 15 to 0 (to help aleviate my P0446 I keep getting) and It did drop my startup RPMS by quite a bit. My car was actually struggling to stay running when first started. I also noticed about 150rpm idle decrease which is obviously very easy to increase but is there something else to make the warmup RPMS slightly higher now to counteract the other?
I was thinking about looking at the Low Coolant Temp Timing and % Low temp timing trim vs coolant temp but I believe those are only for closed loop.
Old May 7, 2009 | 10:23 PM
  #82
Evoryder's Avatar
For those that like visual aid:
Old May 7, 2009 | 10:25 PM
  #83
Wicked E's Avatar
That is awesome as I said earlier. Thanks for posting that!!
Old May 8, 2009 | 08:57 AM
  #84
Evoryder's Avatar
no prob
Old May 8, 2009 | 07:20 PM
  #85
Wiznaz's Avatar
What is being diffused from the hose we pulled from the EGR/Emission Canister and vent to the atmosphere now? Will our car smell like gas fumes now? What will happen if it isn't vented?
I had the throttle hang issue at 3k RPM constantly. I blocked off the EGR and never disabled/removed anything. I thought I had some sort of boost leak. I just horse-shoed a vacuum line from the two nipples on top of the TB and my issue was gone. I'm going to disable the FAA and FCA bits in the ECU and just need to know if I have to actually remove any of the stuff in the diagram above.
Old May 9, 2009 | 08:53 AM
  #86
Evoryder's Avatar
You went 11.52 on the stock cat? ...it should be the same as what you are used to. IF anything you can route it to the back of the car.
You should disable the bits in the ecu...also you did have a boost leak, the 2 nipples source the pressure for the egr...vacuum and psi.
You don't have to remove the stuff in the back if you capped off the nipples, however, you might as well...much cleaner and easier to work on the IM if necessary.
Old May 9, 2009 | 05:05 PM
  #87
Wiznaz's Avatar
The car is catless.. I never said anything about running catted? I did have a boost leak after installing the IM & TB from the EGR until I U'd a vacuum line onto both nipples. That is why the idle was so high. Thanks for your help Ryder!
Old May 9, 2009 | 09:16 PM
  #88
Evoryder's Avatar
^ I was just making light of you worrying about fumes knowing that you don't have a cat hah. You really shouldn't notice the smell, or any different smells.
When I removed the solenoids, I only left the egr solenoid(no lines attached) The fpr and evap were removed and all lines associated gone. Takes about 1hr ...pretty straight forward.
Old May 10, 2009 | 09:15 AM
  #89
Evoryder's Avatar
NOTE: When removing the entire solenoids and hoses disable the following periphery bits.
Periphery 0/FAA:
-EGR(ign advance) Bit 11 disable(some people leave it on, up to you)
Periphery 2/FCA:
- EVAP> Bit 13,14,15 Disable
- EGR > Bit 9 Disable
Periphery 4/FEA:
- FPR> Bit 7 Disable(When you also disable FCA/P2 Bit 15 that will also take care of the FPR)
Old May 11, 2009 | 08:46 PM
  #90
Wicked E's Avatar
Just a correction, FEA is actually Periphery 4 NOT 2.
-E
