Disabling EGR and fuel pressure solenoids
Old Jul 15, 2010 | 06:34 AM
  #226
Evoryder's Avatar
Originally Posted by tscompusa
and what about the bigger outlet on the intake manifold where we use the fuel line clamp on.. that doesnt crack or does it? if so what size is it so i can get that in better quality also
I changed mine from a cap to a fuel hose with bolt inside.
Old Jul 15, 2010 | 09:59 AM
  #227
mrfred's Avatar
Originally Posted by honki24
I've been looking for a cap to go onto the nipple on the heating tube that goes around the back of the motor which used to connect to the heater core. I've purchased EPDM and Nitrile (available at NAPA) and they both crack after several months. This would have to be a big one, I don't know how big off hand but I'd say somewhere around 3/4". I can't find a suitable material for high pressure and temp.
Its actually the hydrocarbons that kill EPDM. I had overlooked that in the chemical compatibility of EPDM. Next best bet would be to get some viton tubing, and use some nylon plugs. Plugs used for drip systems may be good enough.
Old Jul 15, 2010 | 12:18 PM
  #228
nonschlont's Avatar
did i order the right ones? Line Quantity Item Ships Unit Price Total Price
1 1 Pack 92805K31 Push-on High-Temperature Silicone Rubber Cap Fits 3/32" Outside Diameter, 3/4" Inside H, Packs of 100
Originally Posted by Evoryder
That's the one.
thanks guys. gonna order a set of those, right now...
Edit: Just bought a set...
and from reading the other "removal" thread, seems , next, I/we need to get a plug for the head, if we dont already have 1... Labor on that is gonna be a "bia bia"
Old Jul 15, 2010 | 03:27 PM
  #229
tscompusa2's Avatar
dont need to cap the head..... uhm instead of everyone ordering 100 caps, pm me ill send out free just pay shipping.
Old Jul 15, 2010 | 03:29 PM
  #230
tscompusa2's Avatar
picture? a pcv hose with a BOLT in it with a clamp over the hose and bolt? post picture please.
Old Jul 15, 2010 | 04:14 PM
  #231
nonschlont's Avatar
I thought about asking, but figured, WTF. Same offer goes for me...
Old Jul 15, 2010 | 04:45 PM
  #232
Evoryder's Avatar
Later
Old Jul 15, 2010 | 08:12 PM
  #233
Evoryder's Avatar
Old Jul 15, 2010 | 08:15 PM
  #234
tscompusa2's Avatar
Perfect. ill copy that tomorrow but with fuel line clamps i dont have worm clamps that tiny. my next dyno visit ill give you a shoutout in the thread since you help me with boost leak stuff
Old Jul 15, 2010 | 08:29 PM
  #235
Evoryder's Avatar
^ yes! A shout out. lol
The bolt used is a snug fit for the fuel hose. Also added yellow teflon tape + goop. That thing aint going no where and it's fuel hose so don't have to worry about heat / tearing.
Old Jul 15, 2010 | 08:32 PM
  #236
tscompusa2's Avatar
yep. I noticed as soon as I capped off my vac lines on TB my a/f at idle instantly sits at 14.7-15.5 now.. it used to be stuck at 12.5.. now it sounds like a evo that actually has cams. I still get the idle drop/ stall sometimes tho....... you think its the acel and decel tables in the ecu that need tweaked? or possibly i have to readjust the biss and ecu idle rpm?
Old Jul 15, 2010 | 08:37 PM
  #237
Evoryder's Avatar
Could be a bit of both or more. All part of a tune. I would do the Biss first.
Old Jul 15, 2010 | 08:52 PM
  #238
tscompusa2's Avatar
the SAS actuator when engaged it idles at like 1300 where as ecuflash i have it set for 1039 or w/e and by itself it will sit at 1100 now.. so they are all out of wack pretty much. I will play more with it later on, but youre right it is the tune.. its the fuel trim. I never tuned my low fuel trim, just the mid.. the low is pegged at -12. I need to tweak the MAF scaling and get it done. Did you do the screw mod on the maf? where you can peel off silicone on maf and backout some plastic screw to be flush so it doesnt restrict airflow as much? applaudd told me about that one.
My mini battery also died again today after charging it to 100% and not having an issue for 48 hrs, so that mini battery is history.. not dealing with that **** anymore. optima in trunk and done. pos mini battery! I think the battery has lots to do with the issues im having also.
Old Jul 15, 2010 | 09:08 PM
  #239
Evoryder's Avatar
I never tried the maf mod. I'm on SD and haven't looked back since.
I got a redtop in my trunk. Forget the mini battery.
Old Jul 15, 2010 | 09:20 PM
  #240
tscompusa2's Avatar
Im doing the redtop in trunk tomorrow. What kit did you use for the enclosure and etc? What about the SD how is the idle control/ etc..? I should do SD since im flowing massive amounts of air.
