Disabling EGR and fuel pressure solenoids
Old Jul 20, 2010 | 12:50 PM
  #271
Evoryder's Avatar
I don't have hope for the chemical version ...only diff with those are that they are black, they withstand less heat and are slightly stiffer than the pink condom looking ones I got.
  #272
nonschlont's Avatar
Originally Posted by ravnos04
dam...i hate spending money on stuff that turns out like that.
Hope you can exchange for the chem ones if they are indeed thicker
well, I just got off the phone w/ a woman @ mcmaster-carr, and they dont stock the chemical caps. And she couldnt answer if they were any thicker, more durable, or heat resistant...
@ this point, I guess I'll just keep em, strap a couple in, and see how long they'll last. @least till we find another solution...
Im very curious, if this will cure the lil idle issue...
Old Jul 20, 2010 | 03:32 PM
  #273
dsevo's Avatar
Well I was hoping getting rid of the loop and capping both vacuum ports was going to be a jackpot, but my idle is still f'd. I know there's a vacuum leak somewhere in the throttle body, I just need to figure out where. My car won't idle below 1,000 rpm, even with the IAC at 20. Now I'm wondering if that little choke under the IAC could somehow be stuck open, and not closing when the car comes up to temp.
Old Jul 20, 2010 | 03:42 PM
  #274
Evoryder's Avatar
Boost leak test > adjust biss > clean iacv
Old Jul 20, 2010 | 03:51 PM
  #275
tscompusa2's Avatar
ya for some reason i typed out The BISS and throttle cable go hand in hand with idle. did you change either of these yet?
but never hit reply, but im curious how do you clean the iac? nm youtube ftw lol
Old Jul 20, 2010 | 03:56 PM
  #276
dsevo's Avatar
I've done a boost leak test, and cleaned my IACV. I know there isn't a boost leak, I just think there may be a leak that is passing the throttle plate in the throttle body. The only possibilities other than the IACV are the choke under the IACV, and the BISS screw. But my BISS screw is turned all the way in so that the car will idle at 1100 RPM, so I don't think that is the issue. I'm really wondering if my choke could be stuck open. It seems to me that would definitely cause a high idle.
Old Jul 20, 2010 | 05:47 PM
  #277
Evoryder's Avatar
Old Jul 20, 2010 | 05:58 PM
  #278
tscompusa2's Avatar
what the hell is that a coolant loop block for fiav?
Old Jul 20, 2010 | 06:26 PM
  #279
Evoryder's Avatar
forearm builder for hamsters
Old Jul 20, 2010 | 06:41 PM
  #280
Appauldd's Avatar
I used those Vacu-tite caps....they dry rot in no time at all. We need a silicon version.
Old Jul 20, 2010 | 07:02 PM
  #281
Evoryder's Avatar
I'm going to use the oem vacuum line. Those things a much better quality.
Old Jul 20, 2010 | 07:39 PM
  #282
tscompusa2's Avatar
i think the red caps will work we got temp wise, but what are they rated boost wise? i daily drive with 35-36psi, i dont see how its going to hold this.. the caps seem to thin.
i might just have someone weld my lines shut and that will be the end of that problem
Old Jul 20, 2010 | 09:04 PM
  #283
Evoryder's Avatar
I put back the regular caps....4 now
Old Jul 20, 2010 | 10:17 PM
  #284
tscompusa2's Avatar
these will work http://www.boostcontroller.com/index...p%26cond%3DAND
I had one on my car on the bigger outlet on the intake manifold on the dyno but only ziptied on, with that fuel line clamp it wont ever shoot off. those are pure silicone and can handle over 100psi
Old Jul 20, 2010 | 11:37 PM
  #285
Boosted Tuning's Avatar
Did you adjust your BISS using EVOscan?
