Disabling EGR and fuel pressure solenoids
Old Jul 13, 2010 | 08:52 PM
  #196
tscompusa2's Avatar
Originally Posted by Evoryder
Do not loop the nipples. It's NOT a boost leak, it's a vacuum leak after the throttle plate. Won't affect power. It will affect driveability and idle conditions.
like random rpm drop and stalling crap? its what im experiencing..... good to know dude! you always have good **** to bring to the table!
Old Jul 13, 2010 | 08:53 PM
  #197
Evoryder's Avatar
Originally Posted by R0b
its been asked but i cant seem to find the answer.
Whats the correct way to disable all these solenoids for 90550001 or 98640014 without doing it via the periphery codes?
Thanks
Periphery not available for your rom? You might wanna check with MrFred.
Old Jul 13, 2010 | 09:00 PM
  #198
Evoryder's Avatar
Exactly like that. Also carbon build up on or around the throttle plate will cause stall and idle fluctuations. Takes 5 mins to check and 20 mins to remove and clean properly.
Old Jul 13, 2010 | 11:46 PM
  #199
nonschlont's Avatar
Good to know! to fosty and ryder for the clarification. Glad to have u guys around!!!
I specifically asked the guy @ the shop if that was the correct way to set up the vac. lines, and he gave me that look, like c'mon man....
Old Jul 14, 2010 | 04:13 AM
  #200
Evoryder's Avatar
Yeah. Just sucks that I go through nipples every few months. Just been too lazy to make a more permanent solution.
Old Jul 14, 2010 | 04:42 AM
  #201
mrfred's Avatar
McMaster-Carr ought to have viton caps.
Old Jul 14, 2010 | 06:21 AM
  #202
Evoryder's Avatar
Never thought of that.
Old Jul 14, 2010 | 08:55 AM
  #203
kaj's Avatar
kaj
that's what she said.
Old Jul 14, 2010 | 11:07 AM
  #204
Fast_Freddie's Avatar
Veteran: Navy
Now that you red out the throttle plate I see what you are talking about... when I looked at the other thread, I didn't even see the throttle plate... thanks for the heads up!
Old Jul 14, 2010 | 03:30 PM
  #205
nonschlont's Avatar
ok, what size vac. caps do we need???
I got the "Vacu-Tite" pack.
I went out to autozone and they had 2 options, a variety pack of different sizes, and the colorful pack of crappy ones... I got the variety pack, thinking there was 2 of each sizes... lol upon better inspection, theyre all different sizes... I tried to get another pack, but were sold out...
I figured while Im waiting for the motor to cool down, I would try to source out the correct size, and see if I can use what I have, or if I have to go out and find another pack...
TIA
Old Jul 14, 2010 | 06:02 PM
  #206
Evoryder's Avatar
3/32" I believe. SMallest you can find seeing that those nipples are pretty small. I could only find them in the assortment pack that ranged from 3/32" -3/8" ...i bought 2 of those.
Old Jul 14, 2010 | 06:06 PM
  #207
Veteran: Navy
I did the caps today... we will see how it runs tomorrow, I let it idle for about 10 minutes afterwards so it could relearn ISC steps...
Old Jul 14, 2010 | 06:08 PM
  #208
Evoryder's Avatar
^ nice
Old Jul 14, 2010 | 06:11 PM
  #209
Veteran: Navy
BTW I got the Dorman brand caps (3/16") in a pack of 5 for like $1.99 at vatozone... I have had them in the shop for about 3 months... just in case...
Old Jul 14, 2010 | 06:48 PM
  #210
Evoryder's Avatar
^3/16" is kinda big for the nipple. I would go with either 1/8" or 3/32"(3/32 is better because it's a snug perfect fit.)
