Disabling EGR and fuel pressure solenoids
Old Apr 15, 2009 | 10:45 AM
  #61
Wicked E's Avatar
Originally Posted by luvnish
Hey Wicked E,
I want to bypass the FPR solenoid on my Evo5. Do I just run a vacuum line from the manifold directly to the regulator? Should I leave the solenoid plugged in? Do I need to cap off the two ports on the solenoid, loop them, or leave it open?
Can a faulty solenoid cause the FPR to not see boost? I'm getting weird lean AFR readings when I log the car @ WOT, AFR is remaining between 13-14, and that's not good.
Maybe the FPR itself has gone bad? Thus unable to increase the pressure 1:1?
Could it be a clogged fuel filter, dirty injectors, failing fuel pump?
Thanks for your help in advance.
If you have the correct periphery coding to turn off the fpr solenoid code you will not throw a light.
You do NOT need to have the solenoid plugged in and all you do is take a vaccum line straight from the fpr into the intake manifold.
As far as the wot lean condition, its hard to say what it is without seeing the car and/or knowing what the tune looks like.
I can see a faulty solenoid wrecking havoc but I've rarely ever ran into one going bad.
Hope this helps.
-E
Old Apr 16, 2009 | 12:33 PM
  #62
Nesiop's Avatar
Originally Posted by Nesiop
This is slightly off topic, but everyone is talking about the Intake manifold and such. Well I run a AMS VSR manifold and BBK 75mm TBody. This does not have a place for the IAC so it is currently taped up and hanging and not an issue with my AEM, but when I swap to the reflash for emissions, does the IAC throw a code, or can I connect the factory end and let it hang or is there something I can disable as well for that?
WICKED E did you happen to see this? Or have any comments on it?
Old Apr 16, 2009 | 03:07 PM
  #63
Wicked E's Avatar
I apologize... I did not see that post as I was viewing on my blackberry.
I would assume that without the IAC properly functioning on the stock ECU it will run like *** and most likely throw a code for something. I don't recall the IAC having its own code/CEL. You may want to ask the guys at AMS what they suggest doing.
-E
Old May 4, 2009 | 07:32 PM
  #64
SEEnoEVO's Avatar
Originally Posted by evo8dad
Quick question - has anyone had high idle (3K) at cold start up? One the cars I have here now that I have disabled this stuff on has a high cold start up idle. The idle eventually comes down to a purr like idle at 900ish but, was curious to know if anyone has had this issue and what they did to solve it? I assume possibly idle stepper table adjustments?
I have looked through this thread and found no real answer to this. What is the fix for this issue. I am seeing this same thing and feel like an *** with my car warming up at 5am in the morning screaming at 3k. Thanks in advance.
Old May 5, 2009 | 06:22 AM
  #65
Creamo3's Avatar
I noticed the same thing when I disabled the EGR and pulled the plug to the sensor. I'm running ROM 94170015.
Old May 5, 2009 | 11:27 AM
  #66
SEEnoEVO's Avatar
Someone has to have an answer to this.
Old May 5, 2009 | 11:53 AM
  #67
evo8dad's Avatar
Check to make sure FAA bit 11 is enabled. Sounds like this is disabled as it would cause the crazy high idle at cold start up.
Old May 5, 2009 | 11:58 AM
  #68
SEEnoEVO's Avatar
Right now my FAA Bit 11 is 0 which based off the periphery bits thread shows that 0 means enabled.
Old May 5, 2009 | 12:05 PM
  #69
evo8dad's Avatar
I may have referred to the wrong on than. When I get home to the shop I'll double check and post what I find.
Old May 5, 2009 | 04:02 PM
  #70
SEEnoEVO's Avatar
Sounds good. I know there has to be something simple that will help this.
Old May 5, 2009 | 04:06 PM
  #71
Wicked E's Avatar
0 = disable
1 = enable
Old May 5, 2009 | 04:07 PM
  #72
SEEnoEVO's Avatar
If you look at his PDF it states 0 for enable for that bit. I know typically 1 is enable. Is his sheet incorrect?
Old May 5, 2009 | 04:09 PM
  #73
Wicked E's Avatar
No idea what "sheet" you are referring to but every bit I've worked with has been that way.
Old May 5, 2009 | 04:12 PM
  #74
SEEnoEVO's Avatar
mr. freds mapping of periphery bits. Look at FAA bit 11. It states 1 is disable. https://www.evolutionm.net/forums/at...t_20080830.pdf
Old May 5, 2009 | 04:16 PM
  #75
Wicked E's Avatar
You do realize that that whole sheet only applies to the USDM Evo 9?
-E
