Disabling EGR and fuel pressure solenoids
Old May 11, 2009 | 09:37 PM
  #91
Evoryder's Avatar
Thanks E
Old May 11, 2009 | 09:51 PM
  #92
Boost3dxEvO's Avatar
Thanks a lot for the pictures EVORyder and E!!!! Very happy with this thread! a lot of good, useful information!
Old May 12, 2009 | 02:53 PM
  #93
Evoryder's Avatar
Couple shots of my engine bay minus the FPR/EVAP/EGR
(CLICK FOR BIGGER PICS)
Old May 12, 2009 | 04:37 PM
  #94
SWOLN's Avatar
Evoryder^^^ Totally giving me confidence to move ahead with a aftermarket IM. Thanks for the pics and the periphery information.
Old May 12, 2009 | 06:23 PM
  #95
Evoryder's Avatar
^ What manifold? You going big power?
Old May 12, 2009 | 06:57 PM
  #96
SWOLN's Avatar
Ultimate plan is 2.3 TS 40R, but its a ways off... just mentally preparing.
Old May 12, 2009 | 07:03 PM
  #97
Evoryder's Avatar
oh...well the manifold is a start : )
Old Jul 1, 2009 | 12:56 PM
  #98
hotcarbob's Avatar
I am looking at the periphery 2 hex and it is coming up efdf not any kind of number sequence. so how do i input 0x0001? This is on an evo 9.
Old Jul 1, 2009 | 02:27 PM
  #99
Wheatley's Avatar
Originally Posted by Evoryder
NOTE: When removing the entire solenoids and hoses disable the following periphery bits.
Periphery 0/FAA:
-EGR(ign advance) Bit 11 disable(some people leave it on, up to you)
Periphery 2/FCA:
- EVAP> Bit 13,14,15 Disable
- EGR > Bit 9 Disable
Periphery 4/FEA:
- FPR> Bit 7 Disable(When you also disable FCA/P2 Bit 15 that will also take care of the FPR)
When I tried removing all solenoids and following these guidelines I would get a cel and three codes. I have sinced plugged the sensors back in but disconnected from the engine. Anyone else have the same problem?
Old Jul 1, 2009 | 04:52 PM
  #100
Evoryder's Avatar
you are using the old setup...see below
search "mfred" and the periphery thread he created to add the code to your current rom, I don't think you're doing it properly or disabled any of them.
Old Jul 3, 2009 | 02:54 PM
  #101
dsevo's Avatar
Periphery 0/FAA:
Periphery 2/FCA:
Periphery 4/FEA:
When you say disable Periphery 4 bit 7 do you mean set to "0"? The reason I ask is mine is already set to "0". Thanks.
Old Jul 3, 2009 | 03:20 PM
  #102
Evoryder's Avatar
Mine was also. You need to read the quotations.
Old Jul 3, 2009 | 03:40 PM
  #103
dsevo's Avatar
Thanks. Just making sure.
Old Jul 5, 2009 | 07:37 PM
  #104
downshift411's Avatar
[QUOTE=Originally Posted by mrfred View Post
As Mr Turco said, setting FCA bit9 = 0 will disable the EGR OBD-II test, and it will show up as "Not Supported" on an OBD scanner. As far as I know, "Not Supported" is a perfectly acceptable (while "Not Complete" or "Not Ready" is unacceptable). If you run a scanner on your car now, you'll see that there are several tests that are "Not Supported" with a completely stock ROM.[/QUOTE]
Originally Posted by MR Turco
That is correct. Everyone i turn it off in has passed emissions no problem and MA is pretty strict about emissions.
Monitor statuses: CAT, EVAP, SEC. AIR, O2, O2 HTR, EGR. Just want to make sure since MR Turco removed egr and rear 02. i just want to make sure 09 emissions in MA is more strict than ever. do "Not Supported Monitors" still qualify as a pass for MA this year...? cause my i can say 1 of 7 monitors may be ready and the rest N/A? will i still pass or is that the inspectors decision? in a way i highly doubt it. i am running catless but in time im installing a cat and rear 02?
Old Jul 9, 2009 | 02:33 PM
  #105
Wheatley's Avatar
Now in this case if I hadn't disabled any of them wouldnt it throw a cel just from them being unhooked from the engine? I have all three sensors unhooked from the engine but connected to the wiring harness. Runs great. As soon as I removed them from the wiring harness I get a cel. I have tried re flashing and re setting the ecu. As soon as I plug them back in the cel goes away.
I have the periphery on my rom if I didnt I wouldnt be able to turn certain ones off. I also did the 0x0001 set to 0 to disable all FCA, once again if I didnt have the ecu flashed with the proper periphery I wouldnt be able to do that correct?
