Official 2 byte thread!
Old Jan 21, 2009 | 05:55 PM
  #211
tephra's Avatar
yeah in addition 2byte rpm is pretty useless... just slows down logging, regular rpm is fine.
2byte airflow is a good one, and I dont plan on 1byting it anytime soon.
Old Jan 21, 2009 | 09:44 PM
  #212
andrewzaragoza's Avatar
but i would still need to setup the mut table to get the 1byte load working right? so i would still need the address.
Old Jan 22, 2009 | 02:25 AM
  #213
tephra's Avatar
well there is no 5.10 for 88590013
but in 88590015 the MUT (40 or 41) is already programmed with 1byte load, u just need a recent version of evoscan and it will *just work*
Old Jan 22, 2009 | 05:48 AM
  #214
thanks. could i switch his rom from 88590013 to 88590015 without any issues?
Old Jan 22, 2009 | 02:16 PM
  #215
tephra's Avatar
should be fine.
just copy all your tuned maps inc immob
Old Jan 22, 2009 | 03:06 PM
  #216
Thanks. ill try it out.
Old Jan 24, 2009 | 07:36 AM
  #217
Evo8uk's Avatar
Does anyone know the MUT address and 2BYTE adresses for 97250001?
Old Apr 16, 2009 | 08:31 PM
  #218
bambooi's Avatar
So we just buy evoscan and with your version 5.10 of the 88590015 rom, the load we be accurately logged? When does one have to change the 1byte mod number of 1.2 in the version 5.10 of the 88590015 rom?
Old Apr 16, 2009 | 08:52 PM
  #219
tephra's Avatar
yeah:
- run v5.10 or above of my mods
- get evoscan
- if evoscan hasn't already got the 1byte load entry then add it
- log accurately
the 1.2 needs to match it both evoscan formula and in the rom, it just is a multiplication factor that limits the maxload evoscan will see ie:
1.0 = 255 max load
1.1 = 280 mad load
1.2 = 306 max load
1.3 = 331 max load
1.2 should be good enough for 99% of users
Old Apr 17, 2009 | 09:31 AM
  #220
Danieln's Avatar
Somebody please confirmm the right codes for 1 bite and 2bytes mut table for 88840017and for 88840013 also.
V6 seems to have others values than al\lupo confirm at the start pages of this thred.
Give me please correct values for stock rom for both rom versions
Thanks
Old May 12, 2009 | 04:40 PM
  #221
R. Mutt's Avatar
Can someone assist me in finding 2byte load for 95850000. It's a 2004 JDM Evo 8 RS rom. My definition is included in the zip. Thanks for the assistance in advance
File Type: zip
Old May 13, 2009 | 12:55 PM
  #222
nitz's Avatar
i'm not having any luck logging 2byte load on 96260009. it records 0. can someone confirm these are the correct MUT values for this rom.
MUT 00 = 0x8960
MUT 01 = 0x8961
Old May 13, 2009 | 03:10 PM
  #223
tephra's Avatar
they look wrong.
use 0x8984 and 0x8985
Old May 14, 2009 | 05:40 AM
  #224
nitz's Avatar
these were correct for the 96260009 rom. someone please add to first post if possible. thanks dave!
they look wrong.
Old May 15, 2009 | 08:02 AM
  #225
R. Mutt's Avatar
bump
