Too rich AFR's causes knock?
Old May 13, 2009 | 10:14 AM
daymean's Avatar
Hi guys,
Been on the forum for some time, browsing and reading alot...wanna gather as much info as possible before i start modifying my car (E8 MR JDM).
I know that too lean AFR's can lead to knock, but can too rich AFR's also lead to knock?
Old May 13, 2009 | 11:05 AM
clockworktoy's Avatar
Yes overly rich afr's can also cause knock.
Old May 13, 2009 | 11:46 AM
MR Turco's Avatar
it can cause knock. It can also saturate the cylinder walls with gas and prevent proper oiling as well as fuel mixing with the oil.
Old May 13, 2009 | 12:14 PM
daymean's Avatar
hmm....what sort of AFR's would tend to cause this high AFR knock? values less than 10.5 maybe?
Old May 13, 2009 | 12:35 PM
SLO-EVO's Avatar
10.5 AFR is very rich..
Old May 13, 2009 | 12:45 PM
rolly1818's Avatar
Registered User
i have had my AFRs @ 10.5 and have seen no knock.
maybe richer.
Old May 13, 2009 | 01:03 PM
daymean's Avatar
rolly1818, when ur car was stock what afr's did u see?
Old May 13, 2009 | 01:15 PM
kanyonkid's Avatar
stock evos run richer than 10.0 during wot... thats as low as my gauge reads
Old May 13, 2009 | 01:23 PM
rolly1818's Avatar
Registered User
i saw 9.8 after an exhaust install.
Old May 13, 2009 | 08:45 PM
iTune's Avatar
Yes, excessively rich AFR's can and will cause knock. But we're talking AFR's well below 10.0:1 in most cases. Not to mention "Bore Wash".
Old May 14, 2009 | 12:12 AM
I was running 10:1 afr's and it was causing knock in the higher rpm range even after retarding a good amount of timing. Now with closer to 11.3:1 no more knock.
Old May 14, 2009 | 11:14 AM
mrfred's Avatar
One thing that wasn't mentioned is that rich knock looks different than lean knock. Lean knock tends to result in strong knock spikes where as rich knock tends to come on slowly over several hunderd RPM and stay at fairly low levels, usually a knock sum of 5 or less in my experience.
jameswwt
Jun 20, 2012 10:46 AM
grim~
Dec 29, 2011 07:14 AM
EvolutinIX
Jun 13, 2010 12:32 PM
GTR2009
12
Jul 22, 2009 12:46 PM
cij911
Feb 8, 2007 03:30 PM
