TephraMod V7
Old Oct 10, 2009 | 05:25 AM
tephra's Avatar
TephraMod V7
TephraMod V7
yeah finally
First of all I would like to thank everyone who has contributed to the development of this, I reckon some of the new features are awesome
Secondly if you would like to donate just PAYPAL whatever you can/want to donations@globalshare.net
FEATURES
Flashing CEL on Knock
- slow flash for low knock
- fast flash for high knock
- low and high knock thresholds customisable
- minimum load threshold customisable
- can get it to drop boost if above the High knock threshold
Valet Mode
- customisable RPM limit
- autovalet on fresh ignition (ie if you leave the car and come back it will auto valet, as opposed to returning to the previous state you left the car in)
- NOT able to co-exist with TPS based map switching
- CEL will fast flash on ignition if valet is enabled
Alternate Maps
- 3 methods of switching maps - ADC0F (ie Jack_of_Trades harness OR meth failsafe), Intercooler Auto Switch (ie hold down for prescribed time), TPS switching (ie hold TPS like Valet mode)
- all 3 methods WONT switch TO AltMap when car is above load threshold
- ADC0F switching WILL switch BACK to Normal Maps if voltage drops below threshold - hence meth failsafe
BIG MAP
- changed ECU to use new BIGGER MAPS for both Fuel and Timing
- same axis's for both sets of maps
- altmaps and launch maps included
- LOW OCTANGE FUEL AND TIMING INCLUDED as well
- does NOT affect other timing maps, ie EGR or ColdStart
- both Fuel AND Timing use the same Load that the Fuel maps would normal use (ie Load_Baro_n_Temp_Compensated), please keep this in mind for high-altitude tuners
2byte to 1byte load factor
- simple divide routine to convert 2byte load into a 1byte field and then Evoscan will convert back to 2byte.
- MATCH you LoadFactor in ECUFLASH to the SAME as your Eval in evoscan
- MaxLoad is loadfactor * 255, ie a loadfactor of 1.2 will allow a Max Loggable Load of 306, 1.3 = 331... etc (choose an appropriate loadfactor based on your existing max load)
No Lift to Shift (NLTS)
- basically set's a revlimit of whatever your CURRENT RPM is (ie when you shifted) MINUS the RPM Drop you specify in EcuFlash
- Various thresholds ie TPS/Speed/Load so it wont activate by accident
- If you do have problem's its probably your top clutch switch.
- Always do the garage test (ie set speed to 0, tps to 20, load to 0 and then practice the engangement point whilst idling)
AFR Safety
- REQUIRES WB02 wired upto the rear02
- various thresholds and timers
- will Flash CEL AND/OR Drop boost
Launch Maps
- Allows you to customise your "Launch" igition and fuel maps
- various thresholds so it only activates on Launch
- Should override altmap mode as well
FULL Gear based boost control
- removed existing BDEL and BWGDC tables
- added new 3d tables with gear on the X axis
- allows you to have different boost levels AND wastegate duty cycles for each gear
TPS compensation for WGDC
- Basic multiplication table for WGDC
MAF IAT compensation for WGDC
- Allows you to add or remove WGDC based on intake air temp
100% WGDEC under a certain load
- Keeps BCS from openning wastegate under a certain load (to aid in spool up)
Preconfigured MUT Requests
MUT00+MUT01 = 2byte airflow (ie MrFreds mod in g/s or lb/min)
MUT02+MUT03 = 2byte airflow (ie MAFHz)
MUT40 = 1byte gear
MUT41 = 1byte load
MUT42+MUT43 = 2byte SPEED/RPM ratio (to get your gear ratios correct - if you need to)
2byte load AND 2byte RPM are no longer included and IMHO not needed!
INSTALLATION
Wiki Page
This time all you have todo is make sure you have a recent copy of EcuFlash (1.41+ is good) and you just COPY the entire .xml file into your EcuFlash XML directory. No more patching xml files.
BIG WARNING
Whilst I have tried to test everything as much as possible it is up to YOU to test each feature before driving your car around! If you notice any WEIRDNESS (including EcuFlash showing funny values for things) please post up so we can help you! No warranty is provided, and any damage done cannot be held against me!
ROMS
ROMS MOVED HERE
90550001 and 96260009 - "donation only" - meaning if you paypal me (whatever $$$'s its worth to you) I will send you the zip.. if you want it sent to another email address - put it in the paypal message
REPLACEMENT ROMS
969400XX, 964200XX??? - Use 96530706 - See Phemen's first reply down below!!
8884001X - You can use 88580714 with no problems. Just ensure you copy your immobiliser AND 0xFFA bits (yes 0xFFA) otherwise the immobiliser wont work
88570008 + MORE COMING SOON!!!
Old Oct 10, 2009 | 05:26 AM
phenem's Avatar
TephraMod V7-PheNem/l2r99gst/recompile/scheides/bigric09 modified
Updated - 12/19/09
  • Updated XML definitions
  • Fixed EGR issues with both MAF and SD ROM's
  • Fixed decel issue on SD ROM
Updated - 01/10/10
  • Added BAUDRATE and KnockDecay
Updated - 03/09/10
  • Added EVO IX Speed Density modified ROM
Updated - 03/13/10
  • Added EVO VIII 9417 PheNeM Mods and SD ROM's
Updated - 03/14/10
VERY IMPORTANT:
  • Included with each download is a COMPLETE XML Package for the appropriate ROM!
  • Every EVO8 ROM is setup for the Immobilizer HEX for a 2003 USDM car. Change the Immobilizer HEX to your specific car if your car is not a 2003 USDM!
The new ROM ID sequence is as follows:
  • All EVO 8's can use 9653X706
  • USDM EVO 8's can use 9417X715 or 9653X706
  • All USDM EVO 9's will use 8859X715
Replace the X above with the number below:
  • 0 = MAF
  • 1 = Speed Density
  • 2 = DMA (Live Map) + MAF
  • 3 = DMA (Live Map) + Speed Density
IMPORTANT:
  • Make sure you have a recent copy of EcuFlash (1.41+)
  • You have to be in developer user level mode for the BLUE sections to show up in ECUFlash.
  • Copy entire XML package to your ECUFlash XML def. directory for the EVO. Overwrite any files if needed. Edit ROM as needed copying over your Fuel/Timing/Immob/InjectorSize/BoostSettings/etc...
  • If you are going to run SD make sure to adjust your RPM VE and RPM vs. Load to match your current SD settings. Please see this post on Speed Density if you wish to learn more about it and understand what you have to do in order to "tune" for it.
  • If you are having weird issues with your ROM values and items are not displaying correctly please re-download the package again, deleted all associated XML files out of your ECUFlash directory and place the newest correct XML file there.
  • As always if there are issues please post up here: https://www.evolutionm.net/forums/ec...ur-answer.html
Here is an example of all the tables closed up in ECUFLash:
XML Definitions
XML Pack for ALL EVO's - Download | Mirror
ROMS
Evo VIII
USDM 94170015 (Tested on all years of USDM EVO8's)
Option 1 94170715 (v7) - Download | Mirror
  • Stock v7 TephraMOD ROM
Option 2 94170715 (v7 + Mods Omni 4 Bar MAP) - Download | Mirror
  • Set Immob. HEX to 0x0040 (check to make sure your old ROM was the same)
  • mrfred psi based boost implemented for Omni 4 bar as default (just edit Tephra's gear dependant map)
  • OBD II Inspection ready for EVAP and EGR
  • Disabled EGR, EVAP, and Idle Tests
  • Disabled P0300 code
  • Disabled lean spool
  • mrfred double fuel cut load limit implmeneted and set to 300 load (change to whatever you need this to be, read more)
Option 3 94171715 (v7 + Mods + Speed Density Omni 4 Bar) - Download | Mirror
  • Everything that is included in Option 4 minus mrfred double load
  • Speed Density Implemented using the Fuel Temp sensor as input for Temperature
  • Please check the jitter fixes per mrfred - Click here
EDM/JDM/USDM 96530006 (Tested on all years of EDM/JDM/USDM EVO8's)
Option 1 96530706 (v7) - Download | Mirror
Option 2 - Thanks to l2r99gst 96532706 (v7 + Live Map + MAF) - Download | Mirror
  • Set Immob. HEX to 0x0058 (check to make sure your old ROM was the same)
  • Live Map implmented
Option 3 - Thanks to l2r99gst 96533706 (v7 + Live Map + Speed Density) - Download |Mirror
Option 4 96530706 (v7 + Mods) - Download | Mirror
  • mrfred psi based boost implemented as default (just edit Tephra's gear dependant map)
Option 5 96531706 (v7 + Mods + Speed Density) - Download | Mirror
  • Everything that is included in Option 4 minus mrfred double load (not needed when switching to SD)
  • Please check jitter fixes per mrfred - Click here
USDM Evo IX
Option 1 88590715 (v7) - Download
Option 2 - Thanks to recompile 88590715 (v7 + Mods) - Download | Mirror
  • Setup for JDM MAP and PSI based boost control (mrfred)
  • WGDC Correction Interval set to 1 (Stock = 10)
  • Max Total Upward WGDC Correction @ 100% TPS set to 0 (Stock = 10)
  • EGR System Disabled (mrfred)
  • Max Timing Retard set to -20 degrees (tephra)
  • FAA bit.10 disabled ("weird unknown" timing pull at cruise)
  • FAA bit.09 disabled (cat-warmup ignition retard)
  • FBA bit.00 disabled (lean spool)
  • FCA bit.09 disabled (EGR Test)
  • OBD Inspection set to Pass all tests (acamus)
  • Rear O2 Heater patch applied (mrfred)
  • Fuel Cut Load Limit x2 and set to 300 (mrfred)
Option 3 - Thanks to recompile, scheides, and bigric09 88591715 (v7 + Mods + Speed Density) - Download | Mirror
EvoScan XML Data to add:
Code:
<DataListItem DataLog="Y" Color="" Display="Gear" LogReference="Gear" RequestID="40" Eval="x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="5" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="RPM_SPEED_RATIO_AVERAGE" LogReference="RPM_SPEED_RATIO_AVERAGE" RequestID="42" RequestID2="43" Eval="x/36.37" Unit="rpm/kph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Airflow Rate gm/s" LogReference="gmas" RequestID="00" RequestID2="01" Eval="x*0.0236" Unit="gm/s" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="4" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Load 1Byte" LogReference="Load" RequestID="41" Eval="1.3*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="Displays state of the throttle. High voltage or % value means a more open throttle. When logging engine activity (especially on the dyno), it is useful to log throttle position. This makes it easy to see when a power run begins and ends i.e. when the driver's foot is depressing the accelerator fully. Some mitsubishis show up to 20% when your foot is off the accelerator, and will show a max of 90-99% when your foot is fully applied, this is normal.&#xD;&#xA;" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Airflow 2Byte" LogReference="AirFlow2Byte" RequestID="02" RequestID2="03" Eval="6.29*x/64" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="3000" ChartMin="0" ChartMax="2500" ScalingFactor="0.1" Notes="" Priority="4" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Airflow Rate lb/min" LogReference="lbamin" RequestID="00" RequestID2="01" Eval="0.00312*x" Unit="lb/min" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage Gasoline" LogReference="mpg" RequestID="CALC" Eval="5.9*[Speed]*[AFRMAP]/[lbamin]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage E85" LogReference="mpge" RequestID="CALC" Eval="4.18*[Speed]*[AFRMAP]/[lbamin]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />Omni 4-Bar MAP
<DataListItem DataLog="Y" Color="" Display="OMNI MAP" LogReference="OMNIMAP" RequestID="38" Eval="0.2369*x-14.7" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="42" ChartMin="-15" ChartMax="42" ScalingFactor="1" Notes=""/>
Old Oct 10, 2009 | 05:34 AM
tephra's Avatar
BIG MAP Translator:
For Excel 2007 and above
BIGMAP Translator
Old Oct 10, 2009 | 06:33 AM
recompile's Avatar
Well done! If you guys need a mirror let me know.
Old Oct 10, 2009 | 06:49 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Yes!!!!!!!
Old Oct 10, 2009 | 06:57 AM
RyuEvoIX's Avatar
Thank you Tephra and everyone that was involved on this project. Anxiously awaiting 88590015.
Old Oct 10, 2009 | 07:16 AM
phenem's Avatar
Everything is ready for download with the pre-patched 9653 ROM for USDM cars and EDM cars. All you need to do is plug and chug your main maps. Please see above for what is included in each ROM and note all the mods so you know what you need to change and edit to match your cars current tune.
To reiterate the new ROM ID sequence is as follows:
9653X706
8859X715
0 = MAF
1 = Speed Density
2 = DMA (Live Map)
It is important to note that with SD, DMA, and DMA-SD, since there is a new ROM ID, there is a completely new set of XML's that need to be put into your ECUFlash directory.
Old Oct 10, 2009 | 07:17 AM
colonelfox's Avatar
Woohoo! Awesome job.
Old Oct 10, 2009 | 07:31 AM
mlocatel's Avatar
Hello Tephra
the EDM fraction will be very grateful to see you add the 88840017 to your list in the first post
regards
mlocatel
Old Oct 10, 2009 | 07:38 AM
gear head's Avatar
Will the v7t6 live map patch work with v7 or do we need to wait for that patch?
Old Oct 10, 2009 | 07:45 AM
phenem's Avatar
They are working on that portion still. They have to figure out what area in the memory they need to copy over and implement it. I am sure someone will post up a patch soon.
If someone gets the patch working send me an email to phenem at gmail dot com and I will add it to my post above as the live map patch along with my mods.
Old Oct 10, 2009 | 07:48 AM
EVO8LTW's Avatar
Wow...can't wait to get this up and running on my car. Donation coming for sure once I get it downloaded and working!
Old Oct 10, 2009 | 08:14 AM
donour's Avatar
Has anybody noticed that with bigmaps ecuflash's 3d graph widget doesn't display correctly? It get's clipped.
d
Old Oct 10, 2009 | 08:37 AM
SeanV's Avatar
Awesome work guys
Donation coming soon.
Request for 88840016 please. Tried the previous 88840017 mods on a 0016 Evo9, but car refuses to start.
Thx again...
PS: Excellent work on also incorperating the other patches in like Speed Density. Luving this.
Old Oct 10, 2009 | 08:38 AM
phenem's Avatar
d
ECUFlash 1.42 looks OK to me:
