TephraMod V7
Old Oct 12, 2009 | 02:36 PM
  #196
rolly1818's Avatar
Registered User
Originally Posted by phenem
I assumed he knew what he was talking about, LOL!
Looks like he has a JDM EVO 9! So NO he cannot!
i use 88570008 on my car
just wanted to confirm, i guess all you did for EDM to JDM was the rear O2 delete?
Old Oct 12, 2009 | 03:12 PM
  #197
phenem's Avatar
v7 for EVO 9 is still in testing
Old Oct 12, 2009 | 03:19 PM
  #198
tephra's Avatar
AFAIK the MAP sensor is purely used for emissions.
96530006 doesn't care about emisions so it doesn't come with a MAP sensor NOR any scaling tables to "convert" the signal into something the ECU can understand.
Old Oct 12, 2009 | 03:28 PM
  #199
Jack_of_Trades's Avatar
Yeah, we're all on the same page about that now. The problem is with the scalings for the BLEL and BEC when used with PSI based boost control. They need to be scaled for whichever map sensor being used so the numbers in the tables match the actual PSI levels read by the map sensor. All we need to do is have those tables reference the MAP sensor signal rather than LOAD.
Old Oct 12, 2009 | 04:17 PM
  #200
tephra's Avatar
yes of course
Old Oct 12, 2009 | 04:21 PM
  #201
colonelfox's Avatar
I dont want to rush in any way, but is there an ETA on the excel sheet to convert to the big map or did I miss it? Donation sent.
And for crying out loud people, take the time to READ THE ENTIRE FIRST 2 POSTS. Half the posts are "awaiting" a rom that is not coming. They're universal for USDM cars.
Old Oct 12, 2009 | 04:31 PM
  #202
tephra's Avatar
see post #3
Old Oct 12, 2009 | 04:35 PM
  #203
colonelfox's Avatar
Awesome. I did miss it. Thanks.
Old Oct 12, 2009 | 05:42 PM
  #204
l2r99gst's Avatar
OK, I have DMA/livemapping ported over to the V7 final - bigmap for 96530706. I just need some time to test it out and if everything is working OK, I will post up the instructions.
I don't think too many people use DMA/livemapping, but hopefully I can test before the weekend is here.
Eric
Old Oct 12, 2009 | 05:49 PM
  #205
Oettinger's Avatar
Good work!!! U.S.A Roolz! jeje
Old Oct 12, 2009 | 06:13 PM
  #206
recompile's Avatar
The only released ROM is universal to Evo VIII only. v7 for IX has not been released yet, and everyone who's waiting is waiting for 88590015 (IX) or a slight variation.
Old Oct 12, 2009 | 06:15 PM
  #207
Oettinger's Avatar
If you are interested in setting you car up like mine in my video, here is the post I made about what I have in order to get this result:
https://www.evolutionm.net/forums/7171893-post961.html
I see this post. Ok, all -20º and 10.5AFR, but my rom v5 limited to -10º (log with evoscan), with v7 is possible retard ign to -20º?
Or is neccesary one patch in ecuflash with one instruccion(offset, etc)?
Other question... Km/h = 8 and % to 95, and stationary rev limit to 5000? or 7600?
Thanks Phemen!
Old Oct 12, 2009 | 06:28 PM
  #208
Originally Posted by recompile
And it's good you mention the first two posts... they do not make it clear that the ROM is universal to all VIII's, so I could see someone expecting a different VIII ROM being confused.
Good point, it may be helpful for tephra to make a notation near the ROM ID list so people know the deal.
Old Oct 12, 2009 | 06:29 PM
  #209
phenem's Avatar
Thanks Phemen!
Yeah I am not sure if it is actually running -20 degrees or not, I think you have to MOD the ROM which I saw a thread on that.
I would say to set your stationary rev limit to whatever your car launches good at. The way to find out is to do some launch tests and see if it bogs or not.
Old Oct 12, 2009 | 06:33 PM
  #210
phenem's Avatar
Any USDM 8 should be able to run the second map without any trouble and pass emissions and everything.
My post mentions it, I put that up the first day. Doesn't matter just wanted to point out that people don't really read everything even though you make it bold and red in color!
