TephraMod V7
Old Oct 13, 2009 | 02:18 AM
  #226
hediki12's Avatar
Originally Posted by jamie_v1
Does anyone know when 90550001 is going to be released with the V7 patch
I don't think there will be one..... 9653 is going to be the rom of "choice " for evo8 ecu....
Old Oct 13, 2009 | 02:46 AM
  #227
tephra's Avatar
there will be a 905550001 as thats the E7 rom
couple of weeks depending on life
Old Oct 13, 2009 | 03:59 AM
  #228
phenem's Avatar
Originally Posted by jrohner
Why not put the 0 or 1 in the same position for both -- so 96531706 and 88591715?
I didn't think about it and I already made all the XML's for the 9653 and forgot there was already a 1 in the 8859 ROM....people will just to deal with it I don't want to change it.....
Maybe I will get motivated later today to do it
Old Oct 13, 2009 | 05:00 AM
  #229
Oettinger's Avatar
Phenem, when change normal mode to Launch mode the ecu? When is low of 8km/h and when is more of 8km/h is conected on the fly to normal mode(High Octane Fuel Map)?
Afraid change the map on the fly and break motor, all setup is 10.5AFR at -20 ° to full throttle.
Old Oct 13, 2009 | 05:42 AM
  #230
phenem's Avatar
I am sorry but I have no idea what you are asking. I am going to interperet what I think you are asking and answer the best way.
Your question: "How is launch map activated?"
Answer: 8km/h is the the speed the car has to be below in order for launch map to activate. Throttle percentage is the TPS value that the throttle has to be depressed in order for launch maps to activate. So basically both conditions have to be met in order for launch maps to activate. Then if you are on alternate maps it goes to that, if you are not on alternate maps it goes to your main high octane map.
Old Oct 13, 2009 | 06:03 AM
  #231
TouringBubble's Avatar
Originally Posted by phenem
Quick question for you guys, how would you do the number sequence for the EVO 9 guys?
We have consolidated ROM versions such that all Evo VIII ROM IDs share version 96530706 (MAF) and 96530716 (Speed Density) and all USDM Evo IX ROM IDs share version 88590715 (MAF) and 88591715 (Speed Density)
Blue color is tephra version number
Red color is 0 for MAF and 1 for Speed Density
Is this acceptable for everyone or is there a better idea?
What happens with the Tephra patch 10?
I know everyone is familiar with the "88590015" or whatever, but why not do something completely different like 99990107 (9s for Evo IX, 01 for SD and 07 for Tephra patch). So, you've have ...
VIII on MAF - 88880007
VIII on SD - 88880107
IX on MAF - 99990007
IX on SD - 99990107
That way you've got 2 digits for notes and 2 digits for the Tephra version.
Old Oct 13, 2009 | 06:11 AM
  #232
phenem's Avatar
OK guys,
Updated my post and all ROM ID's the following is the standard and I know I should have done this before we released v7 but when you are testing so many things and worrying about everything you need to check then little things get missed.
The following is the new layout:
All Evo VIII ROM IDs share version 96530706 (MAF) and 96531706 (Speed Density)
All Evo IX ROM IDs share version 88590715 (MAF) and 88591715 (Speed Density)
This will stay this way for v7. I don't know if Tephra will be doing any more patches for the CT9A's so we might not have to worry about anything past this.
Old Oct 13, 2009 | 06:15 AM
  #233
Oettinger's Avatar
Ok Thanks! it's a super-men phenem jejejeje. Ok! When is low of 8km/h and 95% is lauch map, other condition is High Octane or alternate High Octane. Perfect!
This weekend do test and will tell you. Thanksss!!!
  #234
phenem's Avatar
IX on SD - 99990107
Great idea if we have to go past v7, talking with Tephra I think he is more interested in moving on to the X now that he has one and they are starting to unlock those ECU's more and more.
This might be the last Tephra patch for CT9A's guys, unless we can talk Tephra into incorporating outputs into the ECU I am not sure there is much else we would need?
Tephra, thoughts?
Old Oct 13, 2009 | 08:40 AM
  #235
jamie_v1's Avatar
Thanks Tephra this will be a big help for me
Old Oct 13, 2009 | 08:45 AM
  #236
daymean's Avatar
I am guessing that the EDM Evo VIII rom will work on my car JDM Evo 8 MR, currently running 96260009...?
Old Oct 13, 2009 | 10:23 AM
  #237
fixem2's Avatar
Just wondering if it is possible to change the TIming increment from 1 point to .5 points like other ECUs. Just a thought for any possible next version.
Old Oct 13, 2009 | 10:31 AM
  #238
Jack_of_Trades's Avatar
It was actually discussed here recently:
https://www.evolutionm.net/forums/ec...esolution.html
Old Oct 13, 2009 | 10:32 AM
  #239
fixem2's Avatar
Missed that thanks!
Old Oct 13, 2009 | 11:41 AM
  #240
03whitegsr's Avatar
We have consolidated ROM versions such that all Evo VIII ROM IDs share version 96530706 (MAF) and 96531706 (Speed Density) and all USDM Evo IX ROM IDs share version 88590715 (MAF) and 88591715 (Speed Density)
https://www.evolutionm.net/forums/ec...xml-files.html
I used the same numbering system.
Includes the Tephra V5.10 patch on 94170015 for those converting over too.
