TephraMod V7
Old Oct 15, 2009 | 06:52 PM
  #361
tephra's Avatar
well the ratios for detecting what gear your are in in the "RPM/Speed to Gear" table will need to be updated based on what gearbox you have.
Old Oct 15, 2009 | 07:01 PM
  #362
Oettinger's Avatar
Originally Posted by tephra
Oettinger - Once I get some more ROM's out I will have a think about your problem
I hope their future news in limitation-ign-retarding for 96530706
Very Thanks tephra!
Best Regards, Ruben
Old Oct 15, 2009 | 07:02 PM
  #363
Jack_of_Trades's Avatar
I edited mine the day you guys released v7 in this thread I would imagine 95% of the Evo8's are the standard 5 speed (which all 5 speeds have the same gear ratios from '03-'05).
Old Oct 15, 2009 | 07:05 PM
  #364
Oettinger's Avatar
Yes, mi evo 8 GSR EDM with this rom(96530006) is 5MT.
Old Oct 15, 2009 | 08:01 PM
  #365
phenem's Avatar
Yeah of course, I did that considering I don't have a 6 speed I assumed I had to change it
I would hope others can figure that out!
Old Oct 15, 2009 | 09:39 PM
  #366
SeanV's Avatar
Originally Posted by SeanV
One last issue I am still having with the big maps relating to Map Tracer and EvoScan V2.7 Beta2......
When doing a maptrace from a log which was done with bigmaps flashed on the car...
I have copied the relevant "bigmap" xml files from the C:\Program Files\OpenECU\EcuFlash - Bigmaps\rommetadata\mitsubishi\evo
folder to the C:\EvoScan v2.7 Beta2\ROMS folder but.....
I still get the following error when I try to open the Hex file with the big maps in.
Anybody been able to get maptracer working with the BigMaps?
Thx
http://i108.photobucket.com/albums/n...titled-2-4.jpg
Bump... so else anyone having the same problems I am with map tracer and the big maps?
No replies makes me think I must be the only one?
Old Oct 15, 2009 | 09:47 PM
  #367
fostytou's Avatar
EvoM Community Team
Thx
(huge img removed)
https://www.evolutionm.net/forums/7078367-post16.html read everything here
Originally Posted by colonelfox
Since the search engine hates to actually search for things other than milwaukees drunkest evo owners, is anyone else having odd load issues? I know my turbo setup is moving some serious air but something tells me that I am not actually in the 5000+ load range at WOT. I also hit serious boost cut that I never hit before but thats probably something I missed porting my maps over. Otherwise the base ROM works well and Im going to give the SD a try this weekend.
Are you sure you are logging the correct load? Are you logging 1 byte load or 2 byte? Did you copy over an old MUT table and overwrite the request you are looking at?
Originally Posted by Oettinger
Tephra see my post #332... Is for create autentic ALS with -15º or -20º, with limitation -10º is very bad the ALS. Thanks
You are welcome to work on adding this to your own rom. This could be included in the definitions, but I personally would want the limit to stay at -10 for my rom. Just retarding the timing more is not true ALS anyway, and the gains are negligible without additional hardware. There is a thread about lowering this value if you so desire (edit:which I see you have found).
Old Oct 15, 2009 | 10:10 PM
  #368
tephra's Avatar
88590715 sent to testers.
Hopefully its bug free...
Fosty - if you want a copy let me know
Old Oct 16, 2009 | 01:49 AM
  #369
YaroRS's Avatar
Do I need to apply MAT patch (using 96531706 rom) to log MAT via fuel temperature input or is it already build in ?
Old Oct 16, 2009 | 04:39 AM
  #370
Oettinger's Avatar
fostytou this option is for all people, for limiting to -10(stock) or more. For creating autentic ALS in ignition is -17 to down.
Old Oct 16, 2009 | 04:47 AM
  #371
Do you have the ALS hardware connected to your exhaust manifold??
Old Oct 16, 2009 | 04:48 AM
  #372
phenem's Avatar
Fosty help me setup my EVOScan to do the map tracer and I am having the exact same issue. When you try and load the BIGMAP it throws an error.
Old Oct 16, 2009 | 04:49 AM
  #373
phenem's Avatar
MAT via fuel temperature input is already built in you would have to change it to IAT sensor if you have one or would want to use that as input.
Old Oct 16, 2009 | 04:50 AM
  #374
phenem's Avatar
He is from Barcelona so he actually might have that hardware needed.
Old Oct 16, 2009 | 04:54 AM
  #375
Yeah I noticed, thats why I asked
