TephraMod V7
Old Jun 27, 2010 | 08:54 PM
  #1861
nj1266's Avatar
I have an 05 USDM Evo 8. Which maps should I use, the 96530706 or the 94170715? Are the bugs fixed in the 9417 rom?
I am using load based ECU boost control with the same numbers for all gears. Which one works better for my application?
Old Jun 27, 2010 | 09:15 PM
  #1862
Boosted Tuning's Avatar
9417 will work on an 05. And I believe the bugs are fixed.
Old Jun 27, 2010 | 09:51 PM
  #1863
nj1266's Avatar
Thanks.
The Tephra 9417 seems to have different tables than the ones I am accustomed to seeing for the MAP sensor. I put the lists in the image below. The Tephra map is missing the Map Scaling, Map Comparison, and the MAP vs. MAF Baro tables.
So how do I set up the tephra tables to log boost with the JDM MAP sensor? What should the values be in the Tephra tables? Any help is appreciated.
Old Jun 27, 2010 | 10:09 PM
  #1864
Thanks.
MRfreds thread about installing MAP sensors should go by the names that are in the tephra .xml.
Old Jun 27, 2010 | 10:58 PM
  #1865
nj1266's Avatar
That is is fine. I have no problem with using different names.
But, are the values for the MAP tables in the Tephra rom the ones to use for logging boost with a JDM MAP sensor? Is the rom ready to log a JDM MAP sensor with the current values in it?
Old Jun 28, 2010 | 08:30 PM
  #1866
UMSTuning's Avatar
Nvm
Old Jun 29, 2010 | 12:37 PM
  #1867
evo 9 MR JDM's Avatar
Hi
Anybody Help Please....
Can I use Tephra V7 with 80092002
mine is Evo 9 MR JDM
thanks
Old Jun 30, 2010 | 02:53 PM
  #1868
nj1266's Avatar
I flashed the 2005 USDM Evo 8 with the 94170715 rom and the car would NOT start. I made sure that the immobilizer code was changed to that in the stock based rom. The car would turn over but it would NOT start.
When I flashed the car back to the 96940011 05 rom, it started right up. I even tried the 96530706 rom and stil the car would NOT start.
I have not had any problems with using the Evo 9 map switching roms posted in this thread. Why are these roms not working?
What is going on here? Can anyone help?
Old Jun 30, 2010 | 02:55 PM
  #1869
RoadSpike's Avatar
Edit:
Hold up do you drive an evo 9? or an evo 8? An evo 8 rom will not work with an evo9..
Disable the immobilizer periphery bit in FAA its towards the bottom with those tables.
It will allow the car to start up normally.
Old Jun 30, 2010 | 03:15 PM
  #1870
nj1266's Avatar
Originally Posted by RoadSpike
Edit:
This is on an Evo 8. So copying and pasting the immobilizer code from the original rom to the 9714 rom will NOT make the car start? Why is that?
Old Jun 30, 2010 | 03:17 PM
  #1871
RoadSpike's Avatar
There is a another hex code which has to match basically the easiest way is to simply disable the immobilizer for now and see if it will play ball.
Old Jun 30, 2010 | 03:28 PM
  #1872
nj1266's Avatar
Thanks man. I will try it and report back to the thread. I was so disappointed that the car did not start.
Old Jun 30, 2010 | 05:29 PM
  #1873
tephra's Avatar
copy over 0xFFA as well (thats the immobiliser thingy RS is talking about)
Old Jun 30, 2010 | 06:19 PM
  #1874
nj1266's Avatar
Can you explain this further? Too cryptic
Thanks
Old Jun 30, 2010 | 06:51 PM
  #1875
tephra's Avatar
http://evoecu.logic.net/wiki/9653000...lacement_Notes
