TephraMod V7
Old Jun 9, 2010 | 12:52 PM
  #1831
RoadSpike's Avatar
I don't know the wiki post you're mentioning so i can't say for sure
Old Jun 9, 2010 | 12:53 PM
  #1832
tscompusa2's Avatar
http://evoecu.logic.net/wiki/File:94170715-v7.zip
that one.. let me know.. if not where is your post with the correct one?
Old Jun 9, 2010 | 01:27 PM
  #1833
RoadSpike's Avatar
Yes that does have the table for fixing it in place however it doesn't tell you what to enter.
<table name="94170715 GEAR Fix1" category="TephraMod-V7" address="3f16e" type="1D" scaling="Hex16"/>
Old 0x6a2c to 0x8a2c
Old Jun 9, 2010 | 01:53 PM
  #1834
tscompusa2's Avatar
thank you
Old Jun 9, 2010 | 03:59 PM
  #1835
tephra's Avatar
fix should be in the zip on post #1 ..
Old Jun 10, 2010 | 02:07 PM
  #1836
Icem@n's Avatar
any luck yet with 9055 v7?
Old Jun 10, 2010 | 03:13 PM
  #1837
ramievo7's Avatar
+1 pleeeeeeeeez
Old Jun 11, 2010 | 06:47 AM
  #1838
wreckleford's Avatar
+2 on 9055.
Old Jun 12, 2010 | 01:52 PM
  #1839
VGergo's Avatar
hello
I'm in trouble with the 94170715 phenem rom psi ecu boost control :O what is your problems ?! will it work download from wiki ? The Option 4 96530706 (v7 + Mods) rom is better ? It also has mrfred psi based boost control. With the 96530706 I shoud write in the Omni power 4 bar calibration ?
In the 96530706 everything is working ?
Old Jun 12, 2010 | 02:27 PM
  #1840
Jim in Tucson's Avatar
Concerning the EVO X Tephra ROM Dave says:
Originally Posted by tephra
If your coming from Evo 7-9 you may notice that there is a slight difference in the algorithm. NOW the CEL lamp will only flash when the knock STARTS above the thresholds. I have done this to stop low load knock from causing the CEL to flash when you pass above the load threshold.
Can this revised algorithm be implemented in the Tephra V7 ROM's?
Old Jun 14, 2010 | 03:30 PM
  #1841
todd6027's Avatar
Originally Posted by wreckleford
+2 on 9055.
+3
Old Jun 15, 2010 | 01:06 PM
  #1842
maximusnz's Avatar
Originally Posted by todd6027
+3
have yous tried the 96532706 v7 rom? ive got this reflashed to my evo 7 ecu on a evo 5 and ive had no problems.. its currently replacing 9055 v5
Old Jun 15, 2010 | 09:48 PM
  #1843
philr8's Avatar
Max the guys with 90550001 want SAS/ALS 96532706 doesnt support this
Phil
Old Jun 17, 2010 | 05:21 PM
  #1844
silex's Avatar
In for updates.
Old Jun 17, 2010 | 05:47 PM
  #1845
tephra's Avatar
I need to send Cossie the 90550701 ROM i did
