TephraMod V7
As i look at my rom, i dont even see that table at all.
i did lol
I'm not sure why that table doesn't show on my own rom or if it isn't needed. The table mentioned above i dont even have, so im not sure how he has it. Either way, i still have a studder with SD, but not sure if it was the SD or something else. When i step on the throttle, there is a delay before the engine revs. Not sure what it is.
i need some help, i have been trying to set up this Launch Map. i have the fuel and timing setup but i am reading in a few places that says to set my stationary setting really high. but what i dont understand is. If i do that then it doesnt stop till redline. If i set my stationary at 5000 like i normaly do it seems to work fine. But i wanted to as ask to be 100%
94170015 UPDATE
Hi All,
Two problems have been found with the 94170015 ROM
1) gear boost doesn't work, it doesn't calculate the rpm/speed ratio at all
2) boost error/tbec doesn't work, my "stock" rom has bad values for the Wastegate activation/deactivation table
I will be posting up fixes for these problems soon - once they are field tested
Sorry for the inconvenience!
Cheers
D
Hi All,
Cheers
D
Thanks,
Chris
yeh I fixed #1...
#2 was an error on my behalf that didn't affect the rom (was looking at the wrong XML
so post #1 should have the gear fixed version up
)so post #1 should have the gear fixed version up
well #2 was just a mistake in MY XML.. so it doesn't actually affect the tephramod rom
the correct XML for wgdc activation/deactivation table should be:
Code:
<table name="Wastgate Solenoid Activation RPM" address="1a68"> <table name="Condition"/> </table>
